affects of having a gsr oil cool on a ls/vtec???
affects of having a gsr oil cooler on a ls/vtec block ???
it wll be and full built ls/vtec..will i benefit from adding this??? will it help with reliablity?
[Modified by jdmhatch94, 4:30 AM 4/29/2002]
Re: affects of having a gsr oil cooler on a ls/vtec block ??? (Phantom)
In order to run the GS-R/ITR oil cooler on a LS/CR-V block you will need to have the following parts:
-GS-R/ITR oil cooler 'sandwich' adapter
-GS-R/ITR oil cooler 'sandwich' bolt that has the threads for the oil filter
-both coolant lines
-GS-R/ITR coolant rail on back of bock
-GS-R/ITR coolant spout going into the back of the block*
* You will need to drill a hole and tap some threads for the spout to go on the block. There is a blank spot on the LS/CR-V blocks where you can drill this hole. I am pretty sure the thread is a 16 X 1.5. Do not quote me on this I have the spout and have looked at the threads and have determined it is a 1.5 pitch thread. I just need to determine the diameter.
I will determine all the necessary information on the coolant spout thread this week. I will share this info as soon as I get it.
-kenji
-both coolant lines
-kenji
Re: affects of having a gsr oil cooler on a ls/vtec block ??? (jdmhatch94)
I have the top two or three of Kenji's four requirements. Drop me and email if you want them.
[Modified by b18bpwr, 8:03 AM 4/29/2002]
j87w
06-24-2013 06:20 PM
