help h22/h2b wont start up - Honda-Tech
Old 06-01-2011, 09:51 PM   #1
Default help h22/h2b wont start up
I just finish putting my motor back in my car. The car won't start or crank. Only a click sound from the starter but I test the starter is still good. I push start the car it will start but it die when I let go the gas. Please help
94 civic
H2b swap
datsun71 is offline   Reply With Quote
Old 06-01-2011, 10:41 PM   #2
Shelton's Avatar
Default Re: help h22/h2b wont start up
Make sure that all the engine grounds are in place. As for the clicking with the starter make sure the spade connector is tight on the starter connection. If it still clicks pull it apart and clean it if you don't have another starter handy.
I pulled this link from hondata, make sure the idle control routing is correct. Adjust accordingly if not... Hope this helps.
http://www.hondata.com/manuals/heats...eatshield.html
Shelton is offline   Reply With Quote
Old 06-02-2011, 06:35 PM   #3
thanks....i got it start up it was the starter, but now got another problem..the engine won't stay on running i gotta press the gas pedal to keep the engine running but the moment i let go the gas pedal the engine die.....i did a compression test it i got 160-180-180-190 is that good or bad...can it be my headgasket made my compression test low, the headgasket kinda thick too...there no check engine light on. im guessing it my valves or pistons ring.....or my timing belt..... what do u guy think
b20b in ej2 wont start but will when push started eg94coupejdm Tech / Misc 6 01-08-2010 01:36 AM
F22 with H22 trans WON'T START miller9779 Honda Accord (1990 - 2002) 11 10-20-2009 08:04 PM
Help!!!!!.....my CIvic ek9 wont start B-motor Honda Civic / Del Sol (1992 - 2000) 18 10-28-2008 03:32 PM
Need Help? spuddo01 Audio / Security / Video 26 03-08-2006 08:31 AM
car wont start, already tried searching verseone Honda CRX / EF Civic (1988 - 1991) 1 07-27-2002 04:10 PM
Tags
car, crank, dont, fires, gas, h22, h22a, h2b, integra, press, run, running, start, starter, stay, swap, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
