Help!! Clutch or Tranny problem
Ok, I recently have problem downshift from 3rd gear to 2nd,
especially when I am in the high rpm(like 4k above)
There is no problem shifting from 5th to 4th, and it's a minor problem with 4th to 3rd.. but if I double clutch or heel toe to downshift, then it will downshift just fine.
Can someone tell me how to check if this is a tranny problem or just clutch problem?
Re: Help!! Clutch or Tranny problem (chusai)
If you find it hard to get into ANY gear, you have a clutch problem.
If you grind going into 1 or 2 gears, you have a trans problem.
Your problem may be a bad 4-->3 and 3-->2 synchro or blocker ring.
I have a problem getting into third sometimes. It will grind, so it scares me and I stop pushing into 3rd, then try again and it goes perfect. What's up with my ****?
