help with b18c1 timing belt change - Honda-Tech
Old 05-24-2003, 12:10 AM   #1
TurboBumblBee's Avatar
Default help with b18c1 timing belt change
ok, i have a b18c1 in my civic hatch.. i took the motor out of my old civic coupe that was totaled.. the timing belt was cut in the accident so i replaced it along with several other parts that needed to be replaced..
now after changing the timing belt and lining everthing up to TDC the motor will not start.. i have checked everything camshafts are lined up and arrows pointing to each other, crankshaft is lined up to mark on block and still nothing.. what else can be wrong? could it be my dizzy?? the motor was torn apart after the accidnt to make sure of any internal damage to the valves and pistons, it was all fine.. please give me tips on how to start this motor.. do i not need to lined up to TDC and be at 16 degrees BTDC?? im LOST!! help
TurboBumblBee is offline   Reply With Quote
Old 05-24-2003, 12:20 AM   #2
b19coupe's Avatar
Default Re: help with b18c1 timing belt change (Hybrid95CivicEX)
Steps to take when a car won't start:
#1-check for spark.
#2-check for fuel.
#3-check compression.
If any of the above checks reveal a problem, troubleshoot the cause-i.e., no spark, check the distributor, coil, igniter etc.
b19coupe is offline   Reply With Quote
Old 05-24-2003, 12:22 AM   #3
sgT
sgT's Avatar
arrows pointing to each other?? i hope you mean timing marks because the arrows should point UP
sgT is offline   Reply With Quote
Old 05-24-2003, 08:44 AM   #4
Default Re: help with b18c1 timing belt change (sgT)
Quote:
arrrows are pointing up... timing marks are lined up
Old 05-24-2003, 09:11 AM   #5
b19coupe's Avatar
Make sure that the ground wire by the thermostat housing is connected.
Old 05-24-2003, 10:07 AM   #6
Default Re: help with b18c1 timing belt change (b19coupe)
yes it is connected.. the fuel pump will not turn of with out that ground strap..
Tags
adjusting, b18c1, belt, change, changing, marks, putting, removal, replace, replacement, setting, tdc, timing, timming, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
