h22 lma shim size is not right?
Old 09-30-2006, 01:20 PM
esohsee's Avatar
Default h22 lma shim size is not right?
i am in the process of putting h22 spring type lmas into a b series head.
the problem is that i read the size difference is .040" but when i measured it myself with a micrometer it reads about .080" different. anyone would like to help me on this one?
Old 10-01-2006, 04:49 PM
esohsee's Avatar
Default Re: h22 lma shim size is not right? (esohsee)
nobody?
Old 10-14-2006, 07:17 AM
B18C Turbo's Avatar
you compared a GSR LMA to the 1999 prelude one and you came up with .080'?
Everyone says to use a .040" shim, im buying mine today.
Old 10-15-2006, 04:02 PM
esohsee's Avatar
Default Re: (B18C Turbo)
yea i know everyone says .040 but when i put the washer under the prelude lma there was a visual height difference...
Old 10-15-2006, 06:30 PM
B18C Turbo's Avatar
yeah I was questioning this too. Im guessing peopel use the .040" washer that sits above the tapered bore in the LMA bore to bring it up to height.
But Earl says the .040" washer that fits in the bottom of the taper in the LMA bore is good to go. So either way I guess works! $1 for the stainless washers at home depot. They are #10 and come in a plastic package with almost 15 of them. Dont even cost $1 and yes they are stainless, they drop right into the bottom of the bore.
22accordts
09-10-2010 09:22 PM
Sam_J
12-31-2006 12:04 PM
AznBlueBoy
08-12-2005 01:32 PM
LearningNewb
03-23-2005 07:08 AM
Quick Reply: h22 lma shim size is not right?
