GSR Rods -- no oil holes?
Old 07-06-2002, 05:06 AM
New User
GruvyTune's Avatar
Default GSR Rods -- no oil holes?
looking at the stock rods in my engine, i noticed the manual shows the rod bearings and rods to have an oil hole in them. My stock gsr rods and rod bearings have no such hole. How does oil get in the bearings then?
thanks!
Old 07-06-2002, 10:17 AM
New User
GruvyTune's Avatar
Default Re: GSR Rods -- no oil holes? (GruvyTune)
ttt
Old 07-06-2002, 11:19 AM
Chiovnidca's Avatar
It is presure fed through the crankshaft from the main bearing journals.
[Modified by Chiovnidca, 3:20 PM 7/6/2002]
Old 07-06-2002, 11:23 AM
New User
GruvyTune's Avatar
Default Re: GSR Rods -- no oil holes? (Chiovnidca)
how? There are no oil holes in there.
Old 07-06-2002, 01:20 PM
earl's Avatar
If u have a gsr crank, there are oil holes cross drilled between crank and rod journals.
Old 07-06-2002, 02:28 PM
New User
GruvyTune's Avatar
Default Re: GSR Rods -- no oil holes? (earl)
I know about those oil holes, i mean the rod bearings. look in the manual and other rods, and they show oil holes in the actual rods that extend to the bearings, the bearings sometimes have holes like the crank bearings. the gsr do not. so how does oil get to the bearing surfaces of the rod bearings?
Old 07-06-2002, 03:29 PM
Chiovnidca's Avatar
Under presure through the crankshaft. The holes on those other rods you are talking about aren't to lubricate the rod bearings, they spray oil out onto the cylinder walls and the bottom of the pistons to aid in lubrication and cooling.
Old 07-06-2002, 06:19 PM
earl's Avatar
The oil comes from the inside of the crank out to the rod bearing surface. It doesn't come from the rods like the d series. What I have a hard time with is how a full floating piston pin lubricates from the hole on top of the rod.
Old 07-07-2002, 08:45 AM
New User
GruvyTune's Avatar
YEA, but there are no holes in the rod bearings themselves so how does oil get to the bearing surface without a hole in one of them like in the mains bearings??
Old 07-07-2002, 09:28 AM
Chiovnidca's Avatar
I'm getting the idea you don't understand. Or mabee I don't. Do your rods have holes in them?
Old 07-07-2002, 09:55 AM
earl's Avatar
The rod bearings oil from inside the rod journal to the surface of the rod bearing. That's the only spot that needs oil. This is unlike the d series oiling.
Old 07-07-2002, 11:56 AM
sgT
sgT's Avatar
Dude, if you still dont understand i will CALL you and explain.
Old 07-07-2002, 12:43 PM
New User
GruvyTune's Avatar
neither my rods nor the rod bearings have holes in them. the crank journals dont have holes in them either so that is why i am asking how the rod bearing surfaces get enough oil.
Old 07-07-2002, 02:25 PM
earl's Avatar
Have you run this crank yet? Are you sure it is a gsr? Post some pix
The rods and rod bearings are not supposed to have holes in them but the crank is
[Modified by earl, 3:27 PM 7/7/2002]
Old 07-07-2002, 04:58 PM
New User
GruvyTune's Avatar
nevermind i understand
Old 07-07-2002, 05:05 PM
Chiovnidca's Avatar
mario_pic
03-15-2010 01:35 PM
EARLdaSQUIRREL
05-31-2007 12:19 PM
turbo boost
01-22-2007 09:45 PM
kwik92hb
12-20-2003 09:07 PM
GruvyTune
07-06-2002 05:09 PM
Quick Reply: GSR Rods -- no oil holes?
