GSR Cylinder head for LS/vtec
Old 08-26-2001, 07:24 AM
Prelussion's Avatar
Default GSR Cylinder head for LS/vtec
I already know how to build the ls/vtec conversion using the b16a1 cylinder head. What I'm wondering is if I have to prep the LS block different if I were to use a GSR head instead of a Si head. Will I still have to drill out the dowel pin holes? And when i go to tap the oil line will it be in the same place?
Old 08-26-2001, 07:52 AM
rainforest's Avatar
Default Re: GSR Cylinder head for LS/vtec (Prelussion)
yes with the dowles,yes with the external oil line. the only diffrance is you will get .2 comression more than a b16a.
Old 08-26-2001, 08:00 AM
Prelussion's Avatar
Default Re: GSR Cylinder head for LS/vtec (rainforest)
Hmmm i think i'll just go with the b16a1 head and have 20 milled off the bottom of it. Also for ls/vtec with a 95ls if i were to use a Si cylinder head which ECU would be good? Is there someplace that sells custom ls/vtec ECUs.
Old 08-26-2001, 01:30 PM
H-PIMP's Avatar
94-95 GSR ECU is your best bet.
pakn-heat
12-01-2009 04:17 PM
98IntegraLSNonVtec
12-10-2005 09:52 AM
NeXTLeVeLGeN2
09-28-2002 10:16 PM
HarryB
07-02-2002 10:36 AM
z crx z vtec z
03-08-2002 10:21 AM
Quick Reply: GSR Cylinder head for LS/vtec
