GSR in 99ek jerking and bucking during normal driving.
Old 11-13-2009, 05:24 PM
jaredvabeach's Avatar
Default GSR in 99ek jerking and bucking during normal driving.
Recently this problem has begun to bug me a lot more than at first. I will be driving down the road,and rpm doesn't seem to matter nor does the selection of my gear but the car will suddenly begin to bog.When I give it 'gas' its a little less responsive untill I give it more and it aggressively jerks. I also noticed today that instead of increasing throttle that if I completely let off of it and then press the throttle again the issues goes away,until further down the road of course.
Cliff
normal driving.
car loses power/bogs.
go to accelerate and the car jerks.
let of throttle completely and problem goes away.
I have swapped the tps off with one I had laying around and no luck. I plan to tinker around with it tomorrow to make sure the TPS is 100% dialed in.
I have also swapped out the guts of the distributor,but I did not use a timing light to set the timing.
Im also under the assumption that perhaps the fact that its a GSR with a golden eagle intake manifold on a durrn p30 ecu that there maybe a chance I could just need a tune.
any help is very much appreciated.
Old 11-13-2009, 06:01 PM
eklum's Avatar
Default Re: GSR in 99ek jerking and bucking during normal driving.
sounds like a mount problem/ valve problem get all new mounts .. especially the one on the firewall. are you still using the gay oem mount or did u get the ones with brackets
Old 11-13-2009, 11:49 PM
jdm inc's Avatar
did u calibrate the tps when u put it on?
https://honda-tech.com/forums/showth...light=obd2+tps
Old 11-14-2009, 12:11 AM
4thgenHB157's Avatar
its the ecu. you removed the secondary butterflys when you switched manifolds. the secondaries have a sensore as well, you need to tune the ecu or put the factory IM on
Old 11-14-2009, 02:31 AM
Not the mounts,plus it has hasports.
Yes,but it started pouring down rain so I didnt have the time to check it after I tightened up the screws. Ill be doing that today after work.
Its on a p30 B16 ecu,im getting a custom base map for the setup mid next week.
Any chance it could be the unused RPM wire since that is used on OBD1 cars but not OBD2. There was a thread about running the wires but it said that if not ran only signs would be a chance of the tach not working. (speed output pin number 9 on OBD1 distributor) Although im using a 99 si harness the wire to the ecu through the engine harness are non existent.
Old 11-14-2009, 10:14 AM
jdm inc's Avatar
Keep us updated. after u check the tps
Old 11-15-2009, 03:47 PM
i set the tps at WOT to 4.5 volts. I also set the idle to about .49 volts but it made my car idle at about 250 rpm. So i raised the idle screw on the throttle lever untill my car idles back at 850-900. Ill know in the morning if the bucking continues.
I do not know what the idle voltage is anymore since I readjusted it just to allow my car to idle.
Old 11-16-2009, 09:45 PM
del_soldier93's Avatar
i had the same problem, but i noticed it jerked when i hit bumps, and violently was an understatement. i thought it was my tps and all that crap... but after i changed almost every sensor under the hood, i noticed the set of grounds that were supposed to be bolted down on the block just behind the passenger side of the head was super loose. everytime i hit a bump that ground would loose connection and it would feel like i was driving my car into a brick wall.. i dont get on here too much but i noticed ur havin almost the same problem i had and i know how bad it sucks...hope this helps
Old 11-17-2009, 02:42 AM
Hmongslik's Avatar
could just be that your clutch is going out and not grabbing....how many miles on it?
Old 11-17-2009, 02:52 AM
99JDMHATCH's Avatar
In for the feed back. I have a similar problem where I can't take mine past 2 grand or it bogs. Not to fun driving around town in fifth only going 35. Mines my TPS just need time to fix.
Old 11-17-2009, 03:25 PM
Seriously not trying to be rude but do not say retarded responses such as motor mounts or the clutch. Please read the described symptoms,its clearly electrical/sensor problem.
Old 11-17-2009, 05:31 PM
stevenDAtegra's Avatar
My main relay is going out and it'll do that once in a while for me. When my fuel pump didn't prime but eventually did, almost every time the car would do what you described. If it primed first try, it never did it
Old 11-18-2009, 02:46 AM
ehhh Ill look into that,it is a possibly. I actually changed out the distributor again for a known good one and it seems to have gotten better. Once I get it put on a proper basemap ill know the results for sure.
Old 11-18-2009, 05:32 AM
kyden's Avatar
have you checked plugs?
i would also set timing..
Old 11-18-2009, 11:54 AM
I serve phở for my babies
ohsnapzafingcu's Avatar
bad plugs will do it
Old 11-20-2009, 04:22 PM
Plugs are pretty new. Ive been on 12 hour shifts so I havent had much time to mess with it. Will update accordingly.
IntegraSpeedB18
08-14-2008 03:56 PM
boostedgsreg
05-15-2008 06:29 AM
ls98hatch
03-25-2008 03:22 PM
cacahead1
05-14-2006 07:05 PM
b18bEG
11-07-2002 09:52 PM
Quick Reply: GSR in 99ek jerking and bucking during normal driving.
