any tips or trick s 4 the linkage pin
Old 11-03-2004, 08:52 AM
Help we my pennies
BLUE EH3's Avatar
Default any tips or trick s 4 the linkage pin
any HTers got any tips or tricks!
Old 11-03-2004, 08:57 AM
JinteDgraM's Avatar
Default Re: any tips or trick s 4 the linkage pin (BLUE EH3)
i could get mine out when i did my swap, but since then i can't get it out when i've had to do clutch/flywheel jobs. Its a pain in the *** changing a clutch under the car with teh trans like, RIGHT THERE...no room.
Anyways, I'd like to know too, because I'll be pulling the engine soon which I'll need to get the pin out.
Old 11-03-2004, 09:03 AM
civic-4-ges's Avatar
Default Re: any tips or trick s 4 the linkage pin (JinteDgraM)
wd40, 8mm punch and a 3-4 lb. hammer
Even if you don't think its going to move, keep at it, it will
Old 11-03-2004, 10:05 AM
EE_Chris's Avatar
Default Re: any tips or trick s 4 the linkage pin (civic-4-ges)
PB Blaster (though not really needed)
8mm non-tapered punch
10lb mini-sledge
As stated - you may not think its moving, but keep at and it will. You'll probably think your going to **** up the shift shaft from banging on that pin so hard - but no worries.
Old 11-03-2004, 10:30 AM
Default Re: any tips or trick s 4 the linkage pin (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">8mm non-tapered punch</TD></TR></TABLE>
Good call
Old 11-03-2004, 10:57 AM
civickiller's Avatar
after amany days with hitting it with a punch for 8 hours a day, i finally gave up on that, found a metal rectangle bar about 2" thick and put it on the top of the shiftlinkage, grabbed my gear pulley and started pushing it out. it finally broke and slide out half centimeter or so and i also broke my gear puller, but then after i broke the rust on the pin i used my punch and it came out easy after that. put a bolt back in, in its place
Old 11-03-2004, 11:19 AM
B18C_EJ8's Avatar
They don't call it the "bitch pin" for nothin... LOL
Old 11-03-2004, 02:08 PM
egchan's Avatar
just drop the trans with the linkage. two bolts and the **** compared to banging on the pin.... id just leave it. i ran in to the same problem a bunch of times. sometimes banging on it does it after time. then there was one where i used an air hammer and it still didn't come out. ended up using a torch with the punch.
Old 11-03-2004, 02:35 PM
sk8rmike's Avatar
Default Re: any tips or trick s 4 the linkage pin (Nodo)
i use an air hammer and about 4 seconds of my time to knock out the ones i do.
Old 11-03-2004, 05:48 PM
PrettyLude's Avatar
hammer and proper sized chisel will do the trick
Old 11-07-2004, 01:50 AM
Help we my pennies
BLUE EH3's Avatar
Default Re: (PrettyLude)
i just want to pay a HT member from NJ to do it.. i got a 5/16 punch (5/16=8mm). this "bitch pin" is bitch
Old 11-08-2004, 03:32 AM
EE_Chris's Avatar
Default Re: (BLUE EH3)
Honestly, if you're using a regular carpenters hammer, it won't cut it. You need something with some mass - 10lb mini-sledge. I tried to get this pin out using the claw hammer initially, but it just didn't have the weight behind it.
And you're using a NON-tapered punch, correct - for the most part, it should look like a bolt with no threads. If it has a taper to it, all your going to do is spread the pin apart while trying to push it out - counter productive to one another.
Also, do you have the car high enough in the air to get a decent swing on it? A small swing radius + little hammer = frustrated you.
Again, beating that ****** out leads one to think they're gonng bend/tweak something from how hard they gotta pound on it - but it is just whats needed.
Old 11-08-2004, 06:11 AM
snatch's Avatar
Default Re: (EE_Chris)
It took me anywhere from a minute to 10 minutes to hammer mine out, depending on how much room I had underneath the car. It does get frustrating, but it will come out.
&lt;---Glad there is no apparent tranny swap in future
Old 11-08-2004, 07:36 AM
tegmech's Avatar
Default Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">It took me anywhere from a minute to 10 minutes to hammer mine out, depending on how much room I had underneath the car. It does get frustrating, but it will come out.
&lt;---Glad there is no apparent tranny swap in future</TD></TR></TABLE>
gettin rusty on me andy??? ten minutes? hehe
i use an impact hammer with a punch. gets it out in like 5 seconds.
Old 11-08-2004, 11:11 AM
PHiZ's Avatar
Default Re: (tegmech)
Pin punch, and hammer it down from the top of the engine compartment (disconnect the stabalizer bar, and get a big *** extension)
-PHiZ
Old 11-08-2004, 12:27 PM
JUN1OR's Avatar
Default Re: any tips or trick s 4 the linkage pin (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">after amany days with hitting it with a punch for 8 hours a day, i finally gave up on that, found a metal rectangle bar about 2" thick and put it on the top of the shiftlinkage, grabbed my gear pulley and started pushing it out. it finally broke and slide out half centimeter or so and i also broke my gear puller, but then after i broke the rust on the pin i used my punch and it came out easy after that. put a bolt back in, in its place</TD></TR></TABLE>
For the record. Do NOT use a bolt in it's place, unless you want a super duper sloppy shifter. I made that mistake.
Hey, you live and you learn, right?
Junior
Old 11-08-2004, 04:27 PM
nevamind's Avatar
Default Re: any tips or trick s 4 the linkage pin (JUN1OR)
yup put a bolt in there and you alway feel like you're in nuetral all the time...I feel it. A key point to get that pin out is use a good size hammer, I spend about 1 hour with a small little hammer, and only less than 1/4 of if come out . When I use a bigger hammer, less than 10 minute
Old 11-08-2004, 06:05 PM
Default Re: any tips or trick s 4 the linkage pin (HIStateEG6)
idk what you guys talking about. my shifter is fine. it shifts perfect. has less play then my friends 5th gen civic. mine is a 4th gen.
but would also like to note that, after i got the bitch pin out, i couldnt seperate the tranny and the shift linkage, so after all that work to get the bitch pin out, i ended up pulling the motor with the shiftlinkage still connected and i didnt need to take out the bitch pin. so thats probably why i dont have much play because it still stuck in position all rusted
Old 11-10-2004, 06:47 AM
ReV LiMiT's Avatar
i dont know what size punch... but an air hammer does the job very well with some wd40.... i got mine out in several minutes.
Old 11-15-2004, 10:56 AM
JUN1OR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">idk what you guys talking about. my shifter is fine. it shifts perfect. has less play then my friends 5th gen civic. mine is a 4th gen.
but would also like to note that, after i got the bitch pin out, i couldnt seperate the tranny and the shift linkage, so after all that work to get the bitch pin out, i ended up pulling the motor with the shiftlinkage still connected and i didnt need to take out the bitch pin. so thats probably why i dont have much play because it still stuck in position all rusted</TD></TR></TABLE>
Yes, it probably is stiff because it is still stuck.
I used what I thought was a perfect size bolt through that hole, and it felt more sloppy than your mom
Like throwin' a hotdog in a hallway if you know what I mean.
Old 11-15-2004, 11:11 AM
mike_belben@yahoo.com's Avatar
Location: not riding any bandwagons in, massachusetts, usa
antisieze when you put it back in
SHG_Beans
18
09-06-2006 03:52 PM
mwagner44903
12
07-29-2005 08:48 AM
Rod.
11-01-2004 11:32 AM
CRseXy
09-30-2004 09:36 PM
Swaped Sol
05-24-2002 04:33 PM
Quick Reply: any tips or trick s 4 the linkage pin
