gear ratios - d16z6 vs d16y8 - Honda-Tech
Old 04-03-2002, 02:25 PM   #1
Default gear ratios - d16z6 vs d16y8
i just wanted to know are the they different or the same.
ps: I heard from someone that the Z6 tranny is a little bit stronger is this true or not
thanks
willyboyK20 is offline   Reply With Quote
Old 12-23-2002, 04:23 PM   #2
thisisntjared's Avatar
Default Re: gear ratios - d16z6 vs d16y8 (willyboyD16)
old post but same unanswered question.
thisisntjared is offline   Reply With Quote
Old 12-23-2002, 04:48 PM   #3
tbisme's Avatar
I have a d16z6 in my si and was wondering how mutch the tranny would take. Are the raitos the same? I put 17" weeles on mine and it slowed it down...... 1/8 mi track. I would like to find a bolt-in tranny with some beef that would give my final Back. what about you,
tbisme is offline   Reply With Quote
Old 12-23-2002, 04:49 PM   #4
Default Re: gear ratios - d16z6 vs d16y8 (tbisme)
im replacing my z6 tranny with a y8 tranny and wanted to know all the differences.
Old 12-23-2002, 05:03 PM   #5
tbisme's Avatar
Default Re: gear ratios - d16z6 vs d16y8 (bleh)
What is the reason for the change did your z6 not hold up?
Old 12-23-2002, 05:41 PM   #6
na i bought the car with a auto to manual swap and the wrong tranny mounts were used. after the axle popped out a few times and screwed things up and got replaced (the axle was replaced twice so far) the right mount was put in and the problem still persisted. my mechanic said i would be best off getting a new tranny.
[Modified by bleh, 8:52 PM 12/23/2002]
Old 12-23-2002, 09:22 PM   #7
anyone know the ratios for a 2000 ex tranny?
Old 12-24-2002, 12:58 AM   #8
The ratios are the same. The y8 is stronger because the shift forks in the z6's are cast aluminum and may break in the middle of your 1-2 shift at the race track and cause you to run a 30sec quarter. The y8 uses steel shift forks. There are other minor differences between the 2 so the better shift forks dont fit the older trannys. The shortest geared d-series tranny I found is the del sol si tranny. My old one used to wind out faster than my current z6.
kinesistech is offline   Reply With Quote
Old 12-24-2002, 03:46 AM   #9
D Tranny Guru
Mista Bone's Avatar
D series tranny god here.............
Only difference gearing wise is 5th gear.
92-95 Civic Si and Sol Si got .750 5th, everything else got .702 5th gear.
Check the link in my sig.......
Mista Bone is offline   Reply With Quote
WTB: d16z6 trans messeduprex Northeast (Sales) 0 12-14-2008 07:40 PM
WTB: d16z6 complete head wfocrx Florida (Sales) 6 03-14-2007 10:59 PM
D16z6 header on a b16? keoji Honda Civic / Del Sol (1992 - 2000) 9 11-12-2004 06:10 PM
wtb: d16z6 kerryk Want to Buy 2 12-12-2002 06:34 PM
skunk2 z6 intake manifold? AThiker Honda Civic / Del Sol (1992 - 2000) 14 10-07-2002 10:04 AM
Tags
750k, 92, d16y8, d16z6, gear, honda, miami, performance, ratio, ratios, regear, stock, tranny, transmission, z6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
