Fuel pump kicks on but no fuel pressure in lines..HELP!!! - Honda-Tech
Old 02-17-2009, 12:37 PM   #1
pr3lude1992's Avatar
Default Fuel pump kicks on but no fuel pressure in lines..HELP!!!
This is on my 88 ef. The other day my car was running perfect went inside a store and came out ten minutes later and the car wouldnt start so I tow it home and find out im not getting any fuel. My main relay's is working perfectly fine and you can here the pump come on so I disconnected the fuel line going to the fuelfilter and no gas comes out when I power the pump. Checked the lines and no kinks or anything. Would my best bet be to try and replace the pump?? Thanks
pr3lude1992 is offline   Reply With Quote
Old 02-17-2009, 05:13 PM   #2
GDD Member
slomofo's Avatar
Default Re: Fuel pump kicks on but no fuel pressure in lines..HELP!!!
Do you have gas in the tank? Is there a kink in the line? Is the fuel filter clogged? You sure you're hearing the fuel pump prime?
Pull the pump out, leave it plugged in, then turn the key and listen for a sound.
slomofo is offline   Reply With Quote
Old 02-17-2009, 09:06 PM   #3
Lol yeah theres gas in it... I actually filled the tank about an hour before it happened. I took the lines off the fuel filter and no gas came out the lines when I powered the pump. im 100 percent positive the pumps coming on I took out the back seat and can hear it perfectly. I also used a multimeter to check voltage and everythings good there. Also no kinks in the lines.. I found a walbro pump kit for a 92-00 civic...does anyone know if this will work in my 88 civic? Thanks
Old 02-17-2009, 10:23 PM   #4
wishingiam's Avatar
There's a rubber hose connecting your fuel pump to the bracket it's on, it's possible that that hose deteriorated.
wishingiam is offline   Reply With Quote
Old 02-18-2009, 09:30 AM   #5
Quote:
Thats a good possibility or maybe it fell off. Would that matter since the tank is full wouldnt it still pick up fuel??
Old 02-18-2009, 12:24 PM   #6
havok hybrid's Avatar
Quote:
I would guess the sock or pick up on the pump is clogged..
Pull the pump.. you will find the problem..
havok hybrid is offline   Reply With Quote
Old 02-18-2009, 04:21 PM   #7
Yeah im gonna do that tonight. I found a walbro pump kit for a 92-00 civic in town I wanna pick up..Will this work in my 88? It doesnt have the electrical connector in the kit either so do you know if they are different connectors or the same? Thanks
Old 02-18-2009, 04:25 PM   #8
I beleive they are the same.. the connector should also be the same.. but i cant confirm that..
the pump will work.
If you look in the markerplace you can get a new walbro shipped overnight for 99.. ?
Old 02-18-2009, 04:46 PM   #9
Thats a good deal but I can pick this up brand new for 75 and have it in tonight as long as everythings the same...I was looking on ebay and they have listings for 88-91 and 92-00 thats why i was wondering if 88-00 were any different and why they wouldnt just put them for 88-00.
Old 02-18-2009, 07:30 PM   #10
Sounds like you will be good to go.. I was just suggesting that new one at a cheap price in event the hardware was needed
Pick the 75Dollar one and call it deal..
Fuel Pressure Loss HELP.! joeybuilt Forced Induction 25 07-25-2015 02:30 PM
civic fuel problems b_boysaiyan Honda Civic / Del Sol (1992 - 2000) 7 01-21-2014 12:41 AM
fuel pump prob 93shadowcivic Tech / Misc 2 11-22-2009 02:42 PM
FS: BRAND NEW OEM honda civic crx fuel pump bambam For Sale 9 09-24-2007 01:40 PM
weird story about fuel pressure... SIK IN DA HED Forced Induction 6 11-29-2002 07:06 PM
Tags
accord, civic, converison, ef, fuel, honda, hondatech, kicks, lines, no, pressure, pump, runs, turns, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
