fuel filter banjo bolt ? - Honda-Tech
Old 05-12-2002, 11:48 AM   #1
Mikey3000's Avatar
Default fuel filter banjo bolt ?
when you tighten the banjo bolt on top of the fuel filter, the holes are supposed to line up with the hose that goes to the fuel rail right? how do you make sure these stupid *** holes line up? i turned my key to the acc so the fuel pump primed, and fuel came squirting out of the banjo bolt area. i wanna figure out why.
Mikey3000 is offline   Reply With Quote
Old 05-12-2002, 12:29 PM   #2
EP3_05's Avatar
Default Re: fuel filter banjo bolt ? (Boss Hogg)
Did you replace the metal seals when you changed the filter??
EP3_05 is offline   Reply With Quote
Old 05-12-2002, 01:14 PM   #3
rolow's Avatar
Default Re: fuel filter banjo bolt ? (91civic)
No the holes do not have to be inline
You are just missing the cruch washers or the old ones need to be replaced
[Modified by rolow, 9:14 PM 5/12/2002]
rolow is offline   Reply With Quote
Old 05-12-2002, 03:12 PM   #4
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (rolow)
i did get all new washers and used them. the holes don't have to line up?
Old 05-12-2002, 04:35 PM   #5
raene's Avatar
No. You'll notice if you pull it off that there's a space around where the holes are on the banjo bolt, so fuel will flow anyway.
raene is offline   Reply With Quote
Old 05-12-2002, 06:01 PM   #6
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (raene)
ok. i took the banjo bolt off, put teflon paste on it, retorqued it to spec and it still sprays fuel. only this time, it sprays it in a different direction than last time. what could this possibly be? could it be that my fuel pressure is too high? i have a fpr which i don't know what the setting is on.
[Modified by Boss Hogg, 11:33 AM 5/13/2002]
Old 05-12-2002, 07:52 PM   #7
t
Are you sure you have both crush washers? one in between the filter and fuel line, and than another between the fuel line and the banjo bolt
t is offline   Reply With Quote
Old 05-13-2002, 06:12 AM   #8
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (t)
yes both crush washers are on and the washer under the relief bolt is on too.
Old 05-13-2002, 06:44 AM   #9
Quote:
. . . . and it still sprays oil.
Where exactly is it spraying out of? All I can think of is that you've a bum washer.
Daemione is offline   Reply With Quote
Old 05-13-2002, 08:34 AM   #10
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (Daemione)
oops i meant fuel of course. it's spraying from right under the head of the banjo bolt. the washers are new. you think i should try switching the two washers around and see what happens?
Old 05-13-2002, 11:29 AM   #11
rolow's Avatar
If you are using crush washers and not plane old washers and it's tq to helms
then every thing should be cool.
Do the banjo bolt or fitting have any marks on them I mean is the crush washer
making good cotact?
Old 05-13-2002, 07:16 PM   #12
Mikey3000's Avatar
i would think that they are making good contact. i have no idea what could be wrong. could it be that the banjo bolt is broken under the head (since that's where it's spraying from)? i can't see any holes or anything though. i'm totally stumped.
[Modified by Boss Hogg, 10:17 PM 5/13/2002]
Old 05-16-2002, 12:53 PM   #13
rolow's Avatar
Did you ever find out what was wrong?
Old 05-16-2002, 12:59 PM   #14
Mikey3000's Avatar
no but i've ordered a b&m fuel pressure gauge kit. that should come tomorrow. it comes with a new banjo bolt. i'm sure that'll do the trick. if it doesn't, i'm sellin' this pos.
fuel filter nightmare iateshaggy Honda Accord (1990 - 2002) 12 04-03-2007 07:07 AM
can you bleed brakes through the banjo bolt? huge230 Honda Civic / Del Sol (1992 - 2000) 8 06-13-2006 04:43 PM
Fuel Filter Banjo Bolt Torque specs??? turboxsi Honda Civic / Del Sol (1992 - 2000) 2 11-16-2005 01:00 PM
mpfi fuel line mr. carpenter Honda CRX / EF Civic (1988 - 1991) 7 07-27-2003 10:25 AM
Fuel Filter leaking from Banjo Bolt (top) Edward911 Tech / Misc 6 02-08-2003 10:48 PM
Tags
1991, banjo, bm, bolt, broken, buy, civic, crush, filter, fuel, honda, hondatech, line, lineup, pump, washers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
