a few code/sesnor q's about h22
Old 04-30-2012, 03:35 PM
reesezrex's Avatar
Default a few code/sesnor q's about h22
ok so im tracking down these gremlins. i have a code for iat, vss, and tps. my car has a very high idle. also wont rev past 5k most of the time. no fast idle control valve or egr but brand new iacv.
i started with tps. ohms tested and had a dead spot and unstabke readings. have 5 volts reference. then tested vss and no reading while spinning tires on jack stands. then tested iat and the sensor was reading 3.5k ohms but no voltage to connector. yes i checked for voltage koeo.
my questions are what will a bad vss cause, bad tps cause, and iat probably thinks its unplugged but what will it do. i also sprayed for vacuum leaks and checked all my hoses.
also i just looked up the sensor testing thread on here that i have book marked for s&g and my tps has green/white wire and map sensor has green blue. what will switching these cause?
btw for thos who dont know this is a 90 crx si with obd1 h22a
yes i searched and dont have a definiteive answer from experience on all .
thanks in advance.
Old 04-30-2012, 05:29 PM
reesezrex's Avatar
Default Re: a few code/sesnor q's about h22
did i forget to say please?
Old 05-01-2012, 12:57 PM
reesezrex's Avatar
nobody?
Old 05-01-2012, 01:32 PM
turbohatch96y7's Avatar
Check for input voltage to all sensors and a ground first then out put voltage I don't have my helms but ill help when I get home. Iat and tps should have 5 volts check for breaks in the harness back to the ecu.
Old 05-01-2012, 01:36 PM
And your iat readings sound really high that sensor may be worn.
Old 05-01-2012, 01:39 PM
If you can takke the dead end connector plugs off and check for voltage there at the yellow blk wires for 12v and the blk green sensor voltage for 5 volts. And test continuity from the blk to youur ground. If there's a problem there you can start taking apart your harness and look for breaks. These older harness wires break easily.
Old 05-01-2012, 04:25 PM
reesezrex's Avatar
the tps has reference voltage, the iat does not. but i think the tps has been switched due to wire colors. looks like the map and tps are switched per this link....
https://honda-tech.com/forums/tech-misc-15/honda-sensors-resistance-chart-anyone-has-1817082/
chinese acrobat
35
11-01-2009 12:00 PM
rtnlsltn
07-18-2007 02:08 PM
92eg6_pino
08-16-2005 07:53 PM
synergy004
07-06-2001 11:45 AM
Quick Reply: a few code/sesnor q's about h22
