Failed SMOG. Too high NO and HC?? - Honda-Tech
Old 03-22-2012, 07:55 PM   #1
Default Failed SMOG. Too high NO and HC??
I just took my car to the smog shop today and I failed the
-NO (PPM) 15mph Mine read:1952 and max is 487 @25mph
-NO (PPM) 25mph READ: 1811 max: 774 @ 25mph
-HC (PPM) 15mph read: 116 max: 66
-HC (PPM) 25mph read: 27 max: 49
Could anyone please help me figure out what's wrong? Or why they measured like this.
my car is 1999 honda civic si
b16a from japan
5 speed
110,000 miles
Si818 is offline   Reply With Quote
Old 03-23-2012, 02:38 PM   #2
TunerN00b's Avatar
Default Re: Failed SMOG. Too high NO and HC??
Put a working cat on it if it doesn't have one.
If the car has an EGR, clean/replace it. Also check timing and AFR. Running lean increases combustion temp. High combustion temps produce NOx pollution.
TunerN00b is offline   Reply With Quote
Old 03-23-2012, 04:12 PM   #3
What's an AFR bro? I'll be checking the EGR valve this weekend and timing. Thanks
Old 03-23-2012, 05:03 PM   #4
TunerN00b's Avatar
Quote:
air fuel ratio
Old 03-23-2012, 07:35 PM   #5
For sure man, thanks for the help.
Old 03-23-2012, 09:25 PM   #6
hybridmiklo's Avatar
this car does not have an egr. From the looks of those numbers you might need a cat. Post up the other readings such as the o2,co and co2 so I can get a better idea of what might be needed.
hybridmiklo is offline   Reply With Quote
Old 06-05-2012, 12:53 PM   #7
piggydog's Avatar
hey guys, hope I'm not thread jacking but I'm running into something similar here are my numbers
1992 Honda Prelude 2.3si
Luckily I saved my test from two years ago
Test from 06/2010 - only thing changed after the test was on 11/2011 the distributor, and a few screws on my gas tank (also had a stock filter on in 2010, 2012 I have KN reusable cone filter)
2010 test - pass
http://i1131.photobucket.com/albums/...0smogtest2.jpg
2012 test - failed
http://i1131.photobucket.com/albums/...2smogtest2.jpg
My 2012 results are so high compared to my 2010 tests. Any ideas, the guy says my timing looks off. Do I need to advance the timing on my car? Would that only fix one of those? Should I run any fuel cleaner or seafoam in the tank, suck some seafoam through the brake booster? Thanks for advice.
piggydog is offline   Reply With Quote
Old 03-13-2014, 09:43 AM   #8
Hey guys. Not trying to jack this issues but i also have the same problem as the guy posted.
My NO is above 120 which needs to be below or at 120.
Does anyone know what i need to do?
xeejay is offline   Reply With Quote
Old 03-13-2014, 05:13 PM   #9
TunerN00b's Avatar
Yeah, reduce the NOx content of the exhaust.
Seriously though, you bumped a 2 year old thread for that? Provide all the numbers from the smog check, the year and model of car, and what mods if any, and maybe someone will have a better answer.
B16A 99 Civic Si FAILED SMOG Si818 Honda Civic / Del Sol (1992 - 2000) 16 06-09-2012 10:11 AM
LS EG Hatch Failed Smog at CA B.A.R. Results Posted! Prodigy [EM2] Honda Civic / Del Sol (1992 - 2000) 19 11-23-2011 03:34 PM
High HC levels CA Smog BlackDB8 Honda Civic / Del Sol (1992 - 2000) 13 10-05-2011 12:31 PM
Prelude failed a smog test; results posted avargas28 Honda Prelude 11 06-14-2009 04:57 PM
Failed smog check!!! Help Nicks95GSR Acura Integra 8 05-21-2008 08:37 AM
Tags
accord, car, cat, changing, fail, failed, hc, hcppm, high, hight, hond, honda, ppm, smog, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
