exhaust sounds like a beehive when vtec engages? help?
So i got a new exhaust system worked up, sounded mean without the muffler on, but i felt pretty stupid having to drive i like that for 2 days
i got the new muffler on, its a comptech muffler with custom piping, the welding is pretty bad on the piping but my welding guy closed up the holes, but when i hit vtec at 4900(correct?) rpm in my gsr the thing just makes this horrendous buzzing sound.
is this a result of an exhaust leak? or is there a possibility there is something wrong with this muffler?
i put new gaskets on the piping all around and it still sounds the same, its really disappointing
Re: exhaust sounds like a beehive when vtec engages? help? (blkb18)
OP its not an exhaust leak, I had the same problem when I ran 2.5'' piping to a magnaflow muffler with no cat and no resinator.
Order a resinator and it should make it sound alot alot better.
Re: (clem kevin)
I just got mine done and I have the same problem.
Mine is 2.5 w/ no cat or resonator to a vibrant muffler.
It sounds REALLY good but im also getting a vibration up top. It sounds almost like the piping is rubbing against something. I’m almost certain that that is the cause. I’ll have to check it out this weekend.
Re: (clem kevin)
Im running a greddy evo2 knockoff exhaust, no cat or res. and it sounds just like you say, i garauntee its not the muffler most likely. Im throwin a cat on mine since it sounds and smells like ******* lol
maybe it is the muffler though if you are running a cat/res
iphatcrxi
08-10-2005 10:20 PM
^MikeG
24
11-09-2004 11:56 AM
ptsiu
09-17-2003 12:43 AM
