Exhaust leak causing Idle problems? - Honda-Tech
Old 07-02-2004, 10:00 AM   #1
Merilious's Avatar
Default Exhaust leak causing Idle problems?
I have a slight idle problem, it will go up and down from 750rpm to 1500rpm when at idle. When I rev the engine there is a pretty bad exhaust leak coming from the stock exhaust manifold. Can an exhaust leak be known to cause an idle problem?
Merilious is offline   Reply With Quote
Old 07-02-2004, 10:35 AM   #2
Merilious's Avatar
Old 07-02-2004, 01:04 PM   #3
LudeyKrus's Avatar
It should not affect anything, unless the leak is above an oxygen sensor.
Usually an idle problem is a bad sensor or vacuum hose.
LudeyKrus is offline   Reply With Quote
Old 07-02-2004, 01:32 PM   #4
Merilious's Avatar
The leak is before the O2 Sensor. Where the four exhaust runners merge into two.
Old 07-02-2004, 01:40 PM   #5
LudeyKrus's Avatar
Then yes, the exhaust leak is prob. the cause of your idle problem.
Old 07-02-2004, 07:19 PM   #6
Merilious's Avatar
OK, thanks.
NEED HELP 96 Acura integra high idle won't go away Tegboii Acura Integra 5 12-09-2016 12:41 AM
91 CRX HF jumpy idle please help! vg_Ace Honda CRX / EF Civic (1988 - 1991) 2 09-08-2010 11:06 PM
H22 civic swap with a/c Idle issues spoink Hybrid / Engine Swaps 0 07-12-2006 04:44 PM
Engine problems mike3 Honda Prelude 2 05-08-2006 09:14 PM
IAC Valve. How it works? And why it needs coolant lines? Ri5e Tech / Misc 15 08-25-2002 09:23 PM
Tags
91, affect, bad, civic, down, engine, exhaust, high, idle, idling, issues, leak, mr2, problem, supercharged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
