EVAP Smog Questions B17A Engine
I have a B17a which will be going into a DB2 chassis, so I don't need to go to the ref, just standard smog. My goal is to keep all of the smog equipment functioning properly but may settle for "looking right" depending on the situation. I also don't want to have to swap parts out every time I smog the car. My main question is regarding the IM and TB.
I'm going to be running an ITR intake manifold (from another thread I ran into, I think it's a USDM manifold). I have a 60mm TB that I'm unsure of the what car it came off of. I'd like to use this TB since I have it (maybe send it to Maxbore) but the problem is it does not have a nipple on top for the red braided hose which normally leads from the TB to the EVAP canister.
Here's a photo of what the red hose should look like hooked up (this is a ITR in an EF):
Now here's a pic of the TB I have, see how that nipple is missing:
I'm wondering if I can use this TB and still hook up the EVAP. I figure I have 2 options:
1) Install a fake nipple on the TB, hook up the hose and hope that the smog tech can't tell. Anyone know what sorts of tests they do on this system?
2) Install the red braided hose onto another nipple. The one on the back of the TB (in the 1st pic I posted it would be the one with the "shitty reducer". But that would supply a lot of vacuum to the EVAP system and I'm not sure what that would do. Plus it's not hooked up to the TB, so maybe the smog tech would notice?
Anyone have any other ideas besides finding a TB with the right nipple on it?
TIA
TIA
Re: EVAP Smog Questions B17A Engine
Find the TB with the right nipple on it. One of the test required for your year car is "The low pressure EVAP test" which you will fail.
Thanks for the help, even though it's not the news I wanted. I've been looking for a TB for a couple weeks now and haven't found a damn thing except overpriced ITR TB's.
If you want to use a later style throttle body like the one you have pictured, and have it be correct for your application (with the vac nipple on top), then these ones will work:
94-95 GSR
94-95 Del Sol VTEC (B16A3)
Unsure of exact years for an ITR throttle body, but its probably the early ones, like a JDM 96-97, or a 97 USDM one.
You could also run a first gen B series throttle body as all of them have the nipple on the top, but then you would need to use a firewall mounted MAP sensor. I have a few first gen B16 throttle bodies laying around if you need one.
94-95 GSR
94-95 GSR
94-95 GSR
Not all first gens have the FITV. Some have the FITV attached to the bottom and some have the FITV attached to the manifold.
Yeah I know, but mine does have the FITV on it. I also have a P61 TB which is one that uses the IM mounted FITV. I'm thinking more and more maybe I'll just use the one w/ the FITV and make a block-off plate.
