ELD Electronic load detector, bad idle
Okay, I got a 91 crx. Before the car would idle at around 800-1000rpm, with all the accessories on (headlights, heater, etc...), but I swapped in my new cams and got it all tuned, but now at idle if I turn any accessories on it will not want to idle right and might idle at like 200-300 rpm. I thought it was the ELD, because it was only putting out 0.5 volts at idle and would drop to 0.2 volts with accessories on. It's suppose to be 4.5 to 5 volts with nothing on, and around 2-3 volts with accessories on. I tried 3 other fuse boxes with the same result. The wire from the ecu to ELD is good, there is a good ground and power going to the ELD. No CEL, the alternator FR system checked out and the battery and alternator are newer (newer wiring also). Any help would be appreciated. Thanks.
Re: ELD Electronic load detector, bad idle
Yeah, voltage going to the ELD is 12 volts with the engine off, and 14 volts with the car running (about 0.5 volts difference from it to the battery). The ground wire is also good. So the only voltage coming out is 1.1 volts, with key in start and engine off and maybe 0.5-0.8 volts with engine running, 0.1-0.4 volts with accessories on. There is no CEL, probably because it's getting low voltage as if it has all the accesories on.
I have turboedit, and it doesn't have a place to disable ELD. It also shows 0.00 volts when datalogging, I guess it should show 0.50 or something. Does the ECU determine the voltage output of the ELD at all?
If I remember correctly, the ELD is an input to the ecu and the ecu will adjust IACV pulsewidth and alternator output accordingly dependant on electrical load on the vehicle...
So to answer your question, I believe the answer is No.
So the ELD should be putting out more voltage. Does it decide what a load is by amperage or by the voltage drop?
Okay, so I tried testing the RF signal from the alternator and it didn't test good. I did as it said and disconnected it, turn the key to on, and it measured 4.66 volts at the B14 (blue alternator input). Then I tried starting it with it disconnected and it idled fine, and the idle didn't drop at all when I had accessories on, but it wasn't charging. It's suppose to go down in voltage (ECU B14 wire)when accessories are on, but it doesn't move at all. I tried testing it with the alternator connector reconnected and the voltage went from 4.66 volts to 1.5-1.6 volts and still didn't change voltage at all when accessories are turned on. I checked the wire for short to ground, but it was fine.
If anybody reading this has a CRX or Civic that is perfectly fine could you check these voltages for me to compare? I don't know why the voltage would drop just by connecting the alternator plug. Also, does anyone have any idea what the other two wires do on the alternator plugs? They are black/yellow and white/blue, they both have 20ohm of resistance to ground so are they some kind of ground wires? Thanks in advance, I really need to know this.
According to this...
http://www.civicforums.com/forums/21...-detector.html
The ELD determines load via current draw (amperage) and the more load on the electrical system, the higher the voltage to the ECU. Thats how Im understanding it...
Then the ECU sees this and activates alternator field circuit to supply the battery..
Have you tried voltage drop tests to and from the ELD/battery/ECU?
What if you tapped into a 5 volt pin and introduced it to the ELD input. It should activate the alternator signal wire and everyting should be at full power, right?
The ELD determines load via current draw (amperage) like some kind of transformer. It then sends a voltage to the ecu depending on the load. More load- more volts to ecu up to about 5v...
ECU sees this and activates alternator wire (FR?) from ecu...
Voltage at the battery is about 14.2 volts, voltage at fuse box is about 14.16 volts, and the ELD power is about 13.98 volts (tried hooking straight to 14.16 with no difference). I thought about doing the bypass, I read a few threads about that, but those were guys with huge stereos and seems kind of a band-aid fix.
Has anyone just used a 1-wire alternator on a Honda? When I remove the connector it idles fine, it just doesn't charge. I think just a basic 1-wire alternator would end all these problems. Could it also idle fine because the alternator isn't charging?
I just read on a old thread, where they just used the black/yellow wire and left the other wires off and it work that way. I'm going to try it out.
I think the better/correct way to measure alternator output is by measuring the amperage output, not necessarily the volts. I forgot exactly why, but it seems like I remember seeing/hearing an alternator can have OK voltage output, but be low on amperage output, and still be bad.
IDK all the theories behind it...
Hopefully some honda electrical gurus can chime in and lend some advice..Good luck either way!
If I turn on the headlights, the voltage will be about 13.8 volts and then when the idle drops down to 400-500 rpm it will be around 13 volts. If I have heater, headlights, high beams it goes down to 12 volts and if I rev it up it goes back up to around 14 volts and then when the idle drops again it goes back down to 12 volts. I'll see what an amperage test will show.
josephcmiller2
Engine Management and Tuning
01-09-2012 07:03 AM
