Mounting Fill Neck of Rad. Below water neck housing of block??
Old 01-22-2010, 10:23 AM
H22EKHATCH's Avatar
Default Mounting Fill Neck of Rad. Below water neck housing of block??
Random question, I am relocating a radiator in my crx and to get the hood clearance I need It seems my only option is to relocate the Rad. off the the bottom of the traction bars.
In doing so The Fill/upper neck of the radiator will sit an inch or two below the the water housing of the block, I know this is not optimally the way the rad. should be set up, but will it cause problems ie, overheating, overworking the water pump etc.
thoughts please
Old 01-22-2010, 12:38 PM
H22EKHATCH's Avatar
Default Re: Mounting Fill Neck of Rad. Below water neck housing of block??
no-one??
Old 01-22-2010, 01:32 PM
Nichelson_Performance's Avatar
i don't see a problem with it. i think it sucks the coolant from the lower hose anyhow
you should be fine
Old 01-22-2010, 01:34 PM
Mikey3000's Avatar
why don't you think it would be optimal? the flow goes from the head into the rad, so I would think it aided the coolant into the radiator. Either way I don't think it matters because the water pump is doing work on the coolant.
Old 01-22-2010, 02:54 PM
H22EKHATCH's Avatar
I initially didn't think it would be a problem, then just recently someone brought to my attention (possibly incorrectly) that setting it up this way is an issue
Old 01-22-2010, 07:13 PM
non-VTEC's Avatar
it will be harder to bleed the air out of the cooling system that way. the air will get trapped at the highest point of the cooling system...which would be the cylinder head in your case..attach a tall funnel to the rad filler neck when bleeding the coolant and make sure you get all the air out.
Old 01-22-2010, 07:59 PM
sandracer's Avatar
You won't cause any problems as long as you make sure you have proper air flow threw the radiator. As far as the filler being lower than the top of the motor, we use a cooling system filler from Vacula on our race cars that works great. It was about $150 and you can get it from Vacula direct or pretty much any tool truck.
LSej1
25
10-24-2011 07:57 PM
black-lude
07-19-2007 12:31 AM
greasemonkee
11-24-2006 01:22 PM
goowakjai
08-02-2005 08:59 PM
legendboy
06-01-2004 06:35 PM
Quick Reply: Mounting Fill Neck of Rad. Below water neck housing of block??
