Do Jdm H22 come with vtec oil pressure switch
Hey wsup, So im looking for my VTEC oil pressure switch on my JDM H22 and theres none. Is that normal.
Re: Do Jdm H22 come with vtec oil pressure switch (ProjectLudeSiR)
are you sure you're looking at it right...it is the green colored connector located "on" the vtec solenoid. it may be dirty or something, but i'm sure it's there. i have a jdm h22a as well and its right behind the distrib on the vtec solenoid itself. there should be another 2-pin grey plug there as well. it's for the solenoid. hope this helps...
Re: Do Jdm H22 come with vtec oil pressure switch (yun_cheezie)
Yeah im checking the right place. theres a bolt where the oil pressure switch should be. what year is yours mine a 96.
some jdm h22's do not come with the pressure switch... and the selonoid itself is a one wire plug
Re: Do Jdm H22 come with vtec oil pressure switch (ek9t)
mine is a 93 JDM h22. and yeah, the other plug is a 1 pin fo the solenoid, typo. i've never seen a vtec motor with out a pressure switch, but i guess it is possible. so it there's a plug there, you should be able to remove it and install one. i have several if you need one.
I don't have a technical explanation, but some of the later H and F block VTEC engines didn't have pressure switches... When I swapped a '93 H22a in a '96 Accord, for a buddy of mine, I had to add pressure switch wiring. The Accord didn't have it. (EX).
As long as you have an ECU that doesn't need a pressure switch, you'll be fine.
-Alex
-Alex
