Difference in Timing Belt B16A, B16A1, B16A2, B16A3 - Honda-Tech
Old 11-30-2010, 05:02 PM   #1
Default Difference in Timing Belt B16A, B16A1, B16A2, B16A3
Hey Guys,
Not sure if this is the appropriate section to post this in.
I have done search but couldn't find anything to answer my question.
Is there any differences in the following in terms of timing belt for B16A, B16A1, B16A2, and B16A3?
I'm buying a timing belt and some places state its specifically for a B16A2 and B16A3.
I have an ODB1 B16A Jap Spec motor and doing full service ie. Belts, Water pump, tensioner and seals and what not.
Just want to confirm before I purchase the belt, water pump and tensioner.
I would assume they are all the same correct? Unless there is extra teeth on the pulleys and so forth.
Thanks Heaps,
Mike
sqishy is offline   Reply With Quote
Old 11-30-2010, 07:02 PM   #2
Technical Hero
HondaPartsHero's Avatar
Default Re: Difference in Timing Belt B16A, B16A1, B16A2, B16A3
same
HondaPartsHero is offline   Reply With Quote
Old 11-30-2010, 07:12 PM   #3
hybridb18's Avatar
All B16/B17 are the same, B18A/B18B/B20 are the same, B18C/B16B/B18C5 are all the same
hybridb18 is offline   Reply With Quote
Old 12-01-2010, 03:44 AM   #4
Quote:
Originally Posted by sqishy View Post
Hey Guys,
Thanks Heaps,
Mike
Since you have the answer,I suggest you look on www.rockauto.com for a timing belt component kit.It has all three parts,and ran me about 85.00 for the whole kit.Just performed the "Major Maintenance" on my CR-V.
n5926g is offline   Reply With Quote
Old 12-01-2010, 01:22 PM   #5
Thanks for all the help and responses guys!
Old 12-14-2010, 07:36 PM   #6
Ok guys, correct me if I am wrong...
The 1991 Integra B18 engine uses a Gates T184 belt, which is 125 tooth
The 1995 Del-Sol B16A engine uses a Gates T227 belt, which is 124 tooth
How can you say the are all the same??
1999 Civic with B16A DOHC engine shows to use the T224 belt which is narrower and only 104 tooth.
I personally have seen all 3 engines and each belt is different, so how can you say they are the same??
racer-rocket is offline   Reply With Quote
Old 12-15-2010, 02:37 AM   #7
Technical Hero
Quote:
He saying all B16/B17 are the same as each other. The B18A/B18B/B20 are the same as each other. The B18C/B16B/B18C5 are the same as each other. Not that all of these are the same.
http://www.gatesoe.com/documents/Gat...ations_web.pdf
You might want to check here again. T227 is for the B16A2 and A3. The T224 you listed is for a SOHC application on the 96-00 Civic as in the D16Y8/Y7/Y5.
jdm b16a timing belt..... Bmfcustoms All Motor / Naturally Aspirated 2 10-09-2012 12:18 PM
d16a6 mini me timing belt help! hatchet_honda Honda CRX / EF Civic (1988 - 1991) 6 10-14-2010 12:08 PM
Correct Method for Timing Belt Tension yosuthnmasa Honda Civic / Del Sol (1992 - 2000) 8 04-08-2008 08:29 AM
Changing timing belt on a b16a rehab_this Tech / Misc 2 06-02-2006 03:38 PM
FS:Honda Genuine Parts B16A Timing Belt, Tensioner, Water Pump oeklm For Sale 1 07-16-2005 10:13 AM
Tags
acura, b16a, b16a1, b16a2, belt, belts, fit, honda, integ, kit, pump, tensioner, timimg, timing, water, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
