difference between d15 and d16
Old 02-09-2008, 11:36 AM
civicxxman's Avatar
Default difference between d15 and d16
I was wondering if any one knew the difference between the d15 crank and rods compared to the d16 crank and rods? what is the bearing difference? I do not have a shop manual handy or I would not be asking these questions.
Thank you
Old 02-09-2008, 12:47 PM
ddd4114's Avatar
Default Re: difference between d15 and d16 (civicxxman)
Is this the info you're looking for?
Old 02-09-2008, 06:21 PM
civicxxman's Avatar
Default Re: difference between d15 and d16 (ddd4114)
what I was asking is are the cranks interchangeable and will a d15's pistons fit a d16 rod using the d15 pins? are they the same stroke with a different bore? I know the bottom end of a d16 is way stronger than a d15. the number's posted were for which motor or all d series? with a few exceptions. I dont need to know if it is logical to do I just want to know if it can be done. thank you
Old 02-10-2008, 10:31 AM
ddd4114's Avatar
The cranks are not interchangeable. The rods are also not interchangeable. The only exception is the d15b crank, which can use d16 rods. I'm not sure about the pistons.
The d16 has a 90mm stroke (as opposed to the d15's 84.5mm stroke). They both have a 75mm bore.
EDIT: I mixed up the first part.
Modified by ddd4114 at 2:48 PM 2/10/2008
Old 02-10-2008, 10:48 AM
civicxxman's Avatar
ok
thanks
Matt91
12
12-12-2009 08:27 PM
Btothe3rdDegree
14
03-02-2004 11:31 AM
altoid
02-22-2003 08:04 AM
turbohf
05-25-2002 08:45 PM
Quick Reply: difference between d15 and d16
