D16 specs vs B16
Old 10-19-2003, 06:37 PM
7thGear's Avatar
Default D16 specs vs B16
D16Y8 VS B16A2
the b16 has .005 liters of displacement over the d16
the compression of the d16 is 9.6:1 and the b16 is 10.2 :1
other than that i'm having a really hard time finding the diffrences between the two
can somoene supply me with
bore/stroke
cam specs
and any other realavent technical info about these two motors, cuz the diffrence of 50 hp is staggering!!!
i know the B is a dohc, but still the diffrence is gianormous, so please, specs welcome!!!
Old 10-20-2003, 09:16 PM
RyanEJ8's Avatar
Default Re: D16 specs vs B16 (7thGear)
The "staggering" difference of 50hp, is actually only more like 33hp.
Old 10-21-2003, 10:52 AM
singlecamrocket's Avatar
Default Re: D16 specs vs B16 (RyanCivic2000)
SOHC vs. DOHC. Better breathing in the DOHC u r also looking at around 1000+ rpm difference in redline and like he said around 30-40 hp. The D16 will produce better low end torque, but you have more power and more potential with the B16. If cost is an issue stick w/ the D16, they are cheap as all sin cause everyone is swapping them out for B-series engines.
Old 10-21-2003, 11:10 AM
Sinner's Avatar
Default Re: D16 specs vs B16 (crvtec00)
sohc are good learning motors... if you blow them, everyone has one.
Nick
95JDM
11-18-2007 08:28 PM
actionfigure
33
10-05-2006 10:03 AM
PHILLIPDEEZ
31
11-23-2004 05:12 PM
Mikey361
04-06-2004 08:30 AM
d16y8EL
01-02-2004 10:17 PM
Quick Reply: D16 specs vs B16
