crv axles
crv axles
i recently picked up a set of jdm 5 lug suspension,... the front hubs use a bigger axle than the normal integra/civic's traditional 32mm nut at the end,... i was told to either change the hubs back to usdm or to put a prelude/accord outer joint on my b series axle,... i know that crv's use a 36mm nut on the outside hubs,... my question is are crv axles the same length as normal b series civic/integra axles?
any information would be greatly appreciated thanks
Re: crv axles (For Hybrids)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by For Hybrids »</TD></TR><TR><TD CLASS="quote">i recently picked up a set of jdm 5 lug suspension,... the front hubs use a bigger axle than the normal integra/civic's traditional 32mm nut at the end,... i was told to either change the hubs back to usdm or to put a prelude/accord outer joint on my b series axle,... i know that crv's use a 36mm nut on the outside hubs,... my question is are crv axles the same length as normal b series civic/integra axles?
any information would be greatly appreciated thanks</TD></TR></TABLE>
ive ran into the same problem before and i went to the GM dealer and purchased a set of the chevy XTREME pickup axles and theyve been working fien ever since GET THOSE AT YOUR LOCAL GM dealer they should work just fine warren
im tearing.......
im tearing.......
Quickridez_3
04-21-2019 01:54 AM
jp8900
11-12-2003 10:27 AM
