Crankshaft Sensor problems! (p1336/p1337) - Honda-Tech
Old 01-20-2004, 10:54 PM   #1
Jon5240's Avatar
Default Crankshaft Sensor problems! (p1336/p1337)
Hey guys my car is throwing a few codes...
P1336 - Crankshaft Speed Fluctuation Sensor Intermittant Interruption
P1337- Crankshaft Speed Fluctuation Sensor No Signal
The thing is, my car is driving fine...well execpt for a idle problem i need to fix. Anyone know whats going on? Is the sensor bad? if so how come it drives normal? I've done a search and most people said distributor, because of the Crankshaft Position Sensor being in the distributor...but when people change them out it does them no good...Has anyone had this problem? Its a 1999 Civic EX...D16Y8, thanks for your help in advance? If the sensor is bad or needs to be replaced is it a pricey part? Oh, I have reset the ECU about 100 times and nothing changes, i start up the car and them boom a CEL...I have driven a few thousnd miles like this and its effected nothing, but in order for vtec to kick it the CEL needs to be off correct? I hear it throws the car in lint mode? But I havent noiced a difference execpt for vtec won't kick it....
jon
Jon5240 is offline   Reply With Quote
Old 01-20-2004, 10:57 PM   #2
Mad Scientist
mmuller's Avatar
Default Re: Crankshaft Sensor problems! (Jon5240)
you cant change that sensor, you have to get a new dizzy or swap th internals with a working one
mmuller is offline   Reply With Quote
Old 01-20-2004, 11:04 PM   #3
Jon5240's Avatar
Default Re: Crankshaft Sensor problems! (mmuller)
So you think that may throw a misfire code every now and then?
Anyone have a D16Y8 dizzy for sale?
Old 01-20-2004, 11:16 PM   #4
Cory man's Avatar
Make sure that its the crank sensor(in the dist) and not the crankcase fluctuation sensor(on the crank gear) with the problems. There is a difference. HTH
Cory man is offline   Reply With Quote
Old 01-20-2004, 11:21 PM   #5
Jon5240's Avatar
Default Re: Crankshaft Sensor problems! (Cory man)
Yeha, thats a problem people have been running into as wel...
Most people w/ the sensor on the crank cant rev over 3500rpms correct?
thats what i gather from searching
Old 01-21-2004, 03:15 PM   #6
Jon5240's Avatar
ttt
Old 01-21-2004, 04:09 PM   #7
JimBlake's Avatar
Default Re: (Jon5240)
P1336 & 1337 are the fluctuation sensor, located at the crank. I think it just uses that sensor to help detect misfiring, it's not REALLY needed for the engine to run.
JimBlake is offline   Reply With Quote
Old 01-21-2004, 04:10 PM   #8
Jon5240's Avatar
Default Re: (JimBlake)
thank you!!!
Old 01-27-2004, 09:16 AM   #9
Goldenboy's Avatar
you still haven't sent me the money you you owe me.. LIke i thought little 19 year scammer
Goldenboy is offline   Reply With Quote
Old 05-11-2006, 08:22 PM   #10
gear_e's Avatar
Have the same problem with '97 Civic LX (P-1336). Which sensor should I replace? Will that affecting performance or gas mileage or else? Need you suggestion if the replacement is really needed... Thanks!
Quote:
gear_e is offline   Reply With Quote
help:00 civic si p1336 skyvang Honda Civic / Del Sol (1992 - 2000) 1 09-29-2009 11:07 PM
1999 Honda Civic DX Manual Distributor Problem kuasa Honda Civic / Del Sol (1992 - 2000) 0 10-05-2008 11:37 PM
Code P1337 Crankshaft Position Sensor markovwgti Honda Civic / Del Sol (1992 - 2000) 3 07-24-2008 12:08 PM
CODE P1337 help Emmanuel2112 Acura Integra 9 07-27-2007 10:14 AM
Misfire or ignition problem Jon5240 Honda Civic / Del Sol (1992 - 2000) 4 10-25-2003 09:35 PM
Tags
1336, 97, civic, code, crank, crankshaft, diy, fluctuation, honda, integra, p1336, p1337, sensor, speed, swap, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
