crank but not starting
Old 06-24-2014, 08:59 AM
arcticbluealex's Avatar
Default crank but not starting
Ok so here's what happened, turned off car went to eat came back out, not starting. I got a check engine light for misfire in cylinder 3. Cranks but wont start and I have no idea what to do.
Here's what I replaced trying to get it to work:
Cap n rotor
Ignition control module
Ignition coil
Main relay
Spark plugs
Im running out of things to replace, its like its not getting gas but I smell gas in the throttle body and hear the fuel pump prime? Any help would be nice
Old 07-08-2014, 12:17 PM
widewhite's Avatar
Default Re: crank but not starting
did u check to see if you were getting spark thru the wires and to the plugs, you could have a faulty dizzy.
Old 07-08-2014, 01:03 PM
holmesnmanny's Avatar
Check for spark and fuel.
Old 07-08-2014, 08:06 PM
civic-steve-94's Avatar
Back to the basics check of spark. Crank engine then pull plugs and check if they are wet with fuel. If you have those check for compression.
tyler100
08-24-2008 06:28 AM
masterp
12-05-2006 02:26 PM
geezer06
10-26-2003 09:14 PM
g2turbo
09-17-2003 08:31 PM
paulzy
12-26-2002 03:46 PM
Quick Reply: crank but not starting
