Could anything other than a bad dizzy throw a crank angle sensor code?
Old 05-07-2003, 01:22 PM
WhiteDSM520's Avatar
Default Could anything other than a bad dizzy throw a crank angle sensor code?
I mean like really bad ignition timing or timing belt being off a tooth or anything like that?
I ask because I've swapped dizzy's and checked wires from ecu harness to dizzy harness and continue to get the code. b16a1 in a 91 crx si wth 90 ls dizzy.
Thanks for any info
Old 05-07-2003, 01:46 PM
Spade's Avatar
Default Re: Could anything other than a bad dizzy throw a crank angle sensor code? (WhiteDSM520)
Not that I know of....cut wires could though.
Old 06-14-2003, 06:44 AM
model x's Avatar
I've got the same problem. This was after I re-did the wiring on my swap to clean it up. I tried two dizzys and I mapped out all the dizzy wires.\
Have you had any luck?
88_hatch_ls
24
09-06-2013 07:45 AM
crxfreak1117
11-28-2007 05:56 AM
nayrone
11-01-2004 12:09 PM
Blaze45
12-13-2003 06:28 PM
Quick Reply: Could anything other than a bad dizzy throw a crank angle sensor code?
