Coolant keeps dissapearing out of overflow reservoir
Hi I keep topping up the coolant in my overflow reservoir but every week or so when I check the coolant reservoir is down very low (but not completely empty).
No matter if I check the coolant overflow reservoir when the car is hot or cold it will be almost empty.
I've checked for small leaks in the cooling system and I can't find any. Car runs 100% fine, with no overheating. No water in oil to suggest it's a blown headgasket. No leaks in the coolant overflow resevoir either.
Any ideas?
Any ideas?
1 Post
Re: Coolant keeps dissapearing out of overflow reservoir
You don't have to have a mix of oil/water or water/oil to have a bad head gasket. It could be lifting just enough to pressurize the system and cause the coolant loss.
Uncle Ben's
03-25-2010 10:27 AM
antifreeze, bad, car, coolant, empty, gasket, head, integra, oil, overflow, overflowing, overheating, plastic, radiator, reservoir
