Common Honda Bolt thread pitch size dimension
Old 08-27-2011, 09:51 PM
  #151
dannydos's Avatar
Default Re: Common Honda Bolt thread pitch size dimension
TPS uses a M5x10
Map sensor uses M4x16
home depot has both
Old 01-21-2012, 10:08 PM
  #152
fullmetalmonkey's Avatar
Heres a tough one, thread size related.... dont know if anyone has ever had this issue. I just put a different tranny into my 98 ek D16y7 5 speed.....what I removed was the 5spd p20 A000 (from what i read in the forums its a 92-95 dx, anyone confirm?)....and it has the standard M14x1.5 for the drain plug, not the overfill, but the drain, with the 3/8" square ratchet hole......the dealer claims its what ALL hondas have from mid 80s to 00, and aside from the M20 overfill plug there is no other sizing......well What i put in was a P20 B000 (from what i read its the shorter gearing EX model from 92-95...confirm?)...i get all the way to the end and realize it didnt come with a drain plug, so i pull the one out of the old a000...no luck its way too small.....I havent confirmed just yet, but holding various wrenches up to the hole, it looks like a 16mm would fit in the same way that a 14mm fits the old plug, and the thread seems to match the 1.5 of the old plug too.....Im sure ill find something that works soon, but any help would still be awesome.
My question is...where did my tranny come from?....do they use M16x1.5 drain plugs in european market, or JDM?
Old 01-23-2012, 09:04 AM
  #153
Update for above post.....found a m16x1.5 oil pan bolt...tried to thread it in and it stopped after about 2 turns, looked crooked too.....threads arent mangled, so im thinking that its a different thread pitch....after some research, it seems like its most likely a 5/8" x 18 tpi, but of course no one carries that......so after MORE research i find that its the same as the 90-95 corvette...since i already plugged it for the time being with a universal rubber expansion plug, ill wait to go to the chevy dealership to get my high performance sports car mod.....but when i do, it should net me like 2hp right?..just like each sticker in my window?.........
Old 08-01-2012, 10:34 AM
  #154
TylerWaynePrice's Avatar
what are the size of the bolts for the o2 Housing on my 96' ek hatch with a b20b turbo?
Old 04-02-2013, 07:20 PM
  #155
d_moua's Avatar
gotta sticky this!
Old 04-14-2013, 03:55 PM
  #156
TheRex90's Avatar
Bolts that hold rear LCA'S to body and shocks on 90 CRX M10-1.25
Old 05-13-2013, 03:10 PM
  #157
H22Krew's Avatar
I have the hardest one to get....you cant even order it from Honda....its an
H22 JDM M2B4 Ringear/viscous differential bolt....14 bolts and not a reverse thread like all the other 10 bolt ring gears from diff honda trannies....I actually need one of these bolts...accidentally cracked one off thinking it was a reverse thread bolt......anyone know where i coluld get one??
Old 07-21-2013, 06:18 AM
  #158
smit7277's Avatar
I found out the hard way that the rod connecting bolts for a b16a2 are 10mm x .80
I know, wierd. Honda wants like $38 for the bolt and the nut and they never have it in stock.
Old 09-19-2013, 06:47 PM
  #159
tkhond@'s Avatar
Great work!
Old 09-25-2013, 08:31 AM
  #160
wildthang's Avatar
Anyone know the bolt size for engine cradle support bolts 2003 RSXtype s?
Old 10-28-2013, 01:04 PM
  #161
Sky Alluvion's Avatar
2002 Honda Accord 4 cyl 4 dr
I am missing the bolts to my passenger side front knee assembly.
I am missing 3 4 inch bolts that I believe go to the strut and or steering knuckle.
I need to find what bolts and the thread pitch for them so I can buy new ones today please help me!!!!!
Old 10-30-2013, 05:44 PM
  #162
H-T White Ops
NOFX's Avatar
Originally Posted by NOFX
This link will help with figuring out some bolt sizes if you have a Honda/Acura part number.
https://honda-tech.com/forums/tech-misc-15/make-up-part-numbers-2048988/
Might want to add it to the first post.
Old 01-29-2014, 10:12 PM
  #163
FASTlittleHONDA's Avatar
Whenever i need questions about bolts n stuff i go to http://www.majestichondanorth.com/, it may help.
Old 03-17-2014, 05:50 PM
  #164
JShockleyDesign's Avatar
Can anyone tell me which nuts I will need to replace the existing ones that are for the top part of the struts on a 96 civic that are under the hood.
Old 04-09-2014, 04:48 AM
  #165
relentlesstech's Avatar
One quick question:
Lower motor mount bolt size
1997 Civic LX / D16Y7
Old 06-01-2014, 07:14 PM
  #166
crankeddelsol's Avatar
Great write up. Helped me out a lot. Thanks.
Old 09-03-2014, 08:41 PM
  #167
Gerk254's Avatar
Need to know the bolt size for driver side motor mount on the bottom side of a 94 civic hatch
Old 09-27-2014, 06:32 PM
  #168
toxic671's Avatar
Default Re: (Taimaishui14)
Originally Posted by Brick Top
D-series head stud thread: M10x1.25
B-series head stud thread: M11x1.5
is this also the thread pattern for he head bolt that goes to he block?
Old 10-08-2014, 05:46 AM
  #169
LSUfan71's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (W O T)
Originally Posted by W O T
How big are the bolts that hold your radius rod to the LCA?
M14?
Those bolts on my '98 Accord are M14-1.5, abt 50mm long.
Originally Posted by IN VTEC
M12x1.25, same as all of the other 17mm head suspension bolts.
It's M12-1.25 for the '95 Accord. M14-1.5 for my '98 Accord.
I bought two M12-1.25 bolts this past Monday based on your post. Got ready to put them in and they were too small. Went to Pull-A-Part yesterday and got two from a '98 Accord. I pulled one from a '95 Accord for comparison and they were two different sizes (Radius Rod to LCA). FYI
Old 10-19-2014, 08:33 AM
  #170
delsolpetty's Avatar
What is the thread size for b18a block to clean the threads for arp head studs? Thanks
Old 10-19-2014, 10:25 AM
  #171
F22Master's Avatar
The answer to that is literally two posts above yours. Do you know how to read?
Old 10-19-2014, 02:52 PM
  #172
I can read just fine. I read it after i posted i misread it the first time.
Old 11-09-2015, 07:19 AM
  #173
pdubbs22's Avatar
Guys. I just wanna say I have purchased 4 m12x1.25 bolts for my b18 block to mount on my engine stand.. despite what I have read for weeks.. those bolts do not thread in more then a turn and a half, why is everyone saying everywhere the Trans bolts are that size.. clearly they aren't. .
Old 11-14-2015, 01:19 AM
  #174
DXJN's Avatar
God this is an awesome thread , *runs into garage to organize his bolt bucket & clean*
Old 03-08-2016, 02:07 PM
  #175
Shaun_'s Avatar
What is the thread pitch on the two 19mm bolts for the rear T mount into the trans on b series?
Quick Reply: Common Honda Bolt thread pitch size dimension
