Common Honda Bolt thread pitch size dimension
Old 12-15-2008, 07:21 PM
  #126
nick lsvtec's Avatar
i thought i would post here instead of making a new thread.need bolt size for transmission bolts.the hole on my block where my trans bolts up is stripped out.i know helicoil isnt the best route to go, but where is the best place to buy it.
Old 12-28-2008, 07:05 AM
  #127
Andrew-L's Avatar
Default Re: Common Honda Bolt thread pitch size dimension
does the thread pitch matter on new wheel studs if i buy matching pitch lug nuts?
Old 01-13-2009, 04:22 PM
  #128
dkrex001's Avatar
what are the bell housing bolt size and the 2 bolts #21 on the rear mount bottom #10
http://www.acuraoemparts.com/delray/...All&vinsrch=no
and when i sad that i got a 12x1.25 it was a die and i tryed it on my suspension bolts and on the tranny to motor bolts and it did not work 12x1.25 is to small
Old 02-11-2009, 09:08 AM
  #129
carbonlaced's Avatar
Anyone know the thread pattern and size for the upper table bolts. They stand out on the shock tower and wouldnt mind if anyone knew who sold cosmetic bolts in that size
Old 03-24-2009, 04:23 AM
  #130
lxstuart's Avatar
Does anybody know the size of the banjo bolts on the brake calipers (for a civic)?
I'm pretty sure they're M10 but I don't know if the thread is 1.25 or 1.5 (hell, maybe even 1.0)
Thanks guys.
Edit: OEM part no is :- 46462-SE0-000
Old 03-31-2009, 02:30 AM
  #131
lxstuart's Avatar
Thanks guys.
Turns out they're M10 x 1.00
Old 04-05-2009, 08:31 AM
  #132
alexg103's Avatar
hey can some one pm me with the size of the bolts that hold the motor mount bracket to the block on a d series they had ripped out lsat night and my motor fell to the ground!!!!!:S
Old 04-12-2009, 03:16 AM
  #133
Silencer RPMs's Avatar
thanks for the sticky
Old 04-22-2009, 07:50 AM
  #134
egb18c5's Avatar
having some trouble looking for these tranny bolts, any body have the part number to make my life a little easier?
Old 05-10-2009, 05:54 PM
  #135
Linh.'s Avatar
Yep, What is thread pitch for the bolts that connect the rear tranny bracket to the tranny. I think its M12-1.25 but not positive
Old 07-23-2009, 09:51 AM
  #136
New User
FrenchLake's Avatar
Luserkid, helpful post, I may be getting back to you from some more info.
Old 09-10-2009, 05:57 AM
  #137
Milab21's Avatar
can anyone tell me the bolt size for si trans to bolt to a b series block? m12-1.25 or m14-1.5???
IT IS M12x1.25 BOLT
Old 09-24-2009, 10:38 PM
  #138
New User
Zombie Butcher's Avatar
there should only be two different pitch threads for most cars - coarse and fine.
Old 09-28-2009, 12:26 AM
  #139
Matyikaaa90's Avatar
hi
Could anyone tell me which is size of bolt what shows the picture?
Is it special?
The person who made my head forgot to take back this bolt into my head...
I'm from Hungary but I hope you'll understand my English
Thank you!
Old 10-15-2009, 08:03 AM
  #140
jdmthug's Avatar
any body know the bolt sizes for the lower motor mount bracket on the b-series...
Old 06-24-2010, 04:58 AM
  #141
0TT
0TT's Avatar
Originally Posted by DEIVIONCRX
Anybody know the size and pitch of the Fuel Banjo bolt on the Fuel Filter.
M12. dont know the length.
I need the ECU coolant temp sensor thread size/pitch if anyone can help please
Old 07-02-2010, 07:20 AM
  #142
Lifex's Avatar
looking for the pitch and diameter of the shifter in a 3rd gen/1987 civic hatch . . . . i wanna say m10 1.75 but i don't think that exists since I would like to try and change the shift **** to 1.25 pitch (thats whats on the shift ****
Old 08-16-2010, 01:13 PM
  #143
bjscivic's Avatar
The intake and exhaust manifold studs are M8x1.25 I believe. Is this correct? I remember seeing a thread a while ago about getting some extended stainless ones from Mcmaster to compensate for the Hondata/etc IM gasket. What would be a good length for these (extended of course)
Old 09-10-2010, 01:40 PM
  #144
jjohn170's Avatar
90042-PR3-000 ( 6x28 ; double ended threaded rod that fits into the block and used to hold on the oil pan)
Im looking for any other part number for this threaded rod besides the OEM one. or the dimensions for both thread sides and/or the shoulder.
these mad mama jamas are $3.50 a piece at the stealership.
please pm me with response
Old 09-30-2010, 04:09 AM
  #145
H-T White Ops
NOFX's Avatar
This link will help with figuring out some bolt sizes if you have a Honda/Acura part number.
https://honda-tech.com/forums/tech-misc-15/make-up-part-numbers-2048988/
Might want to add it to the first post.
Old 10-09-2010, 07:11 PM
  #146
natethegreat54's Avatar
does anyone know the thread pitch for a 94 honda civic crankshaft pully bolt ?
Old 12-24-2010, 01:00 PM
  #147
projectpat84's Avatar
Hey I have a question about where I can buy bolts for my 1995 Honda Accord 2.7l V6 EX its the automatic.
With this car there have been several bolts that like to break on me impact wrench or just a regular socket, but anyways my latest one to break is the rear brake caliper a 12mm bolt the one that slides in and out of the boot.
I need to figure out which bolt this is where to buy it and if there's an easy way to get the bolt out or should I let a shop work on it thanks for any info
Old 03-30-2011, 04:53 PM
  #148
f@sth@tch89's Avatar
Anyone know the nut size for the Hydro tranny studs for the motor mount? and also the one for the driver side mount? Need to get the mounts on so I can drop it in the car!!!
Old 04-18-2011, 01:16 AM
  #149
661rex89si's Avatar
anyone one know the nut size for the intake manifold studs on the head to bolt up the IM.
Old 06-06-2011, 11:15 AM
  #150
Method_2o8's Avatar
superb info bro
Quick Reply: Common Honda Bolt thread pitch size dimension
