Cometic headgasket reuse question?
Old 09-27-2007, 01:25 AM
djnikko's Avatar
Default Cometic headgasket reuse question?
I have a freshly built H22A engine with a cometic headgasket. The head bolts have been torqued down but now I want to do some port polishing so Im wanting to take the head off. Can the gasket be reused?
cheers
Old 09-27-2007, 02:42 AM
rd91sib18c5r's Avatar
Default Re: Cometic headgasket reuse question? (djnikko)
No, you risk blowing the head gasket and doing it all over again.
Old 09-29-2007, 10:57 AM
be18see1's Avatar
i actually thought the car had to go through one heat cycle, but im no pro. i just had a similar issue, and those cometic gaskets are starting to add up lol.
Old 09-29-2007, 11:01 AM
djnikko's Avatar
Default Re: Cometic headgasket reuse question? (be18see1)
Thats why I asked, the gasket is quite pricey to just throw away if the gasket blows then its no biggy i'll just have a spare to hand but just wanted to see if anyone has tried this and whether it became the weak point of the engine build?
the engine has not been started at all since the gasket was fitted. Its not even in the car. Can I re-use it then retorque a couple of ft lbs more?
Old 09-29-2007, 11:03 AM
civicstar's Avatar
IMO when i do that, i spray on some copper head gasket spray
Old 09-29-2007, 01:31 PM
Since it hasn't been run i would give it a shot
Old 09-29-2007, 03:39 PM
Lubo_25's Avatar
it sucks man but they're not reusable you could copper spray her ever so lightly but the crush zones have already been depressed use at own risk...
THE GREEN CRX//
02-09-2014 06:35 AM
DelSol-B-18
04-08-2005 06:46 AM
Drag-Accord
03-23-2005 10:20 PM
drewlee
08-09-2004 12:00 PM
Quick Reply: Cometic headgasket reuse question?
