Clutch/Tranny Question
Sushi Buffet Champion
I have two problems:
1) It's hard to get into first gear. I need to use some force. I find it easier to put it in 2nd then up to first.
2) When in first gear and clutch is not engaged yet (foot is still on clutch pedal), sometimes the engine jerks like I'm in gear, pushes the car like I'm in gear then stalls...but clutch has no engaged, clutch pedal is pressed all the way down.
Please help, TIA.
Please help, TIA.
Re: Clutch/Tranny Question (mugensport9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 »</TD></TR><TR><TD CLASS="quote">i think thats a bad clutch and not the tranny</TD></TR></TABLE>
that's what i was gonna say but....maybe synchros?
Re: Clutch/Tranny Question (ITR#132)
So you guys think it's the clutch? I don't understand, it's a brandnew clutch and I just dropped in my motor this month, so all I fluids should be full. What about getting in first gear? It's hard to get into first too.
Re: (jeiden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeiden »</TD></TR><TR><TD CLASS="quote">it's got to be your clutch, it's not disengaging completely</TD></TR></TABLE>
Half the time it does this, not always. Can this be fixed or am I screwed until I replace a new clutch?
Re: Clutch/Tranny Question (GapxGuy)
well i got the same problem as you . but my car didnt wanna get into gear at all.. so then some guy that i met at a kragen store he said something was wrong saying air was getting into the tranny. some other people say that i didnt have my cover where my tranny is so thats why air get into there. and then i didnt have oil in my tranny either. my tranny gots 151,xxxx miles and i dont know what do use. people told me to use 10x30 motor oil. what do i do? anybody?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy »</TD></TR><TR><TD CLASS="quote">I have two problems:
Please help, TIA.</TD></TR></TABLE>
Re: (NeoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR »</TD></TR><TR><TD CLASS="quote">try checking/bleeding the slave cylinder</TD></TR></TABLE>i think thats what was wrong with mines..
Re: Clutch/Tranny Question (Kunfusion209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kunfusion209 »</TD></TR><TR><TD CLASS="quote">well i got the same problem as you . but my car didnt wanna get into gear at all.. so then some guy that i met at a kragen store he said something was wrong saying air was getting into the tranny. some other people say that i didnt have my cover where my tranny is so thats why air get into there. and then i didnt have oil in my tranny either. my tranny gots 151,xxxx miles and i dont know what do use. people told me to use 10x30 motor oil. what do i do? anybody?</TD></TR></TABLE>
Interesting...I haven't put on the cover for my tranny either. You're talking about the rubber boot for the lever fork right?
If the rubber boot over the release arm or the cover plate on the bottom of the bell housing are missing, they can let road crud get into the clutch area. The throwout bearing has to slide smoothly on the transmission input shaft area for the clutch to work properly. Failure to clean and grease the part the bearing slides on or replace the throwout bearing are common causes of poor clutch release on all cars. Degraded fluid or air in the clutch hydraulics will also cause the problem, try pumping the clutch pedal a few times and see if that helps, if it does then the fluid should be bled out just like bleeding brakes. The pushrod that connects the clutch pedal to the master cylinder is adjustable. The shop manual gives an adjustment procedure, give that a try too.
Re: Clutch/Tranny Question (Mohudsolo)
I'm missing #5. I can pump the clutch pedal 2-3 times and it's still hard to get into first gear. It's much easier going into 2nd then into first.
