clutch pedal
Re: clutch pedal (D-Dot)
it's pretty easy to adjust the clutch pedal from under the hood. just follow the cable that goes from the pedal down to the tranny. all i have ever worked on is cable clutches, all you have to do is tighten or loosen the plastic white piece. it's pretty simple. i had to do that when my clutch plate started slipping, it wasnt the best idea, but when your broke and you NEED your car, it seems like a good idea. it made my car last longer, but it ***'d up the pressure plate and flywheel a little too.... good luck....
groundedcivic91
07-15-2006 09:59 PM
TRE_
12
01-21-2003 05:48 PM
