check engine light is on and wont go over 3000 rpm - Honda-Tech
Old 05-13-2004, 12:47 PM   #1
BRAWDY03's Avatar
Default check engine light is on and wont go over 3000 rpm
i recently changed my tranny, and everything worked fine until about 2 mins after its on the check engine light comes on and it runs like crap(wont go over 3000 rpm), i made sure all of my connections are plugged in about 50 times. a buddy of mine says it could be my map sensor and i called a couple of mechanics and they all said the same thing. and i also heard that theres a way to jump some wire to give me a code to tell me exactaly whats wrong with it, but i dont know how to do that either, can anyone give me advice???
BRAWDY03 is offline   Reply With Quote
Old 05-13-2004, 01:00 PM   #2
Katman's Avatar
Default Re: check engine light is on and wont go over 3000 rpm (BRAWDY03)
Did you re-connect the ground wire that mounts to the tranny casing when reinstalling your trans ?
what year is your vehicle?
Katman is offline   Reply With Quote
Old 05-13-2004, 01:52 PM   #3
VtecDeMoN's Avatar
Well is your CEL coming on? If you don't know how to pull the codes, run a quick search of the archives.
Brian
VtecDeMoN is offline   Reply With Quote
Old 05-13-2004, 02:08 PM   #4
Got_Saki60's Avatar
If your car is OBD-II (96 or newer) you can go to Auto Zone and they will hook in for free and tell you what the error is.
Got_Saki60 is offline   Reply With Quote
Old 05-13-2004, 02:24 PM   #5
BRAWDY03's Avatar
Default Re: check engine light is on and wont go over 3000 rpm (Katman)
its an 0BD0 1990 civic sedan 1.5
Old 05-13-2004, 06:51 PM   #6
hondaguyef's Avatar
Check your grounds especially, the one on the thermostat housing. I have seen this many times before. Also pull up your carpet and see which code it is throwing. Make sure if you do find a loose or disconnected ground that you reset your ECU
hondaguyef is offline   Reply With Quote
Old 05-20-2004, 12:29 AM   #7
popngen's Avatar
bump bump any new developments? would help me out a lot... similar problem.. almost exact.. wrong p28 chip i think...
i haven't tripped the ecu plug with a paper clip...
popngen is offline   Reply With Quote
Old 12-07-2009, 06:34 PM   #8
New User
Dominican000's Avatar
ok.. i got the same problem.. 2006 civic si.. the car was on a mini accident.. i fixed it.. changed the intake because the stock 1 was messed up... i had to buy the MAF sensor.. so i put it in... now it wont go over 3000 rpm with out the sensor connected.. when i connect the sensor the cars goes over 3000.. but shuts off... it wont stay on for more than 10 secs... i too it to auto zone.. the codes say the MAF and IAT is bad.. thats all.. but i bout the MAF brand new at the dealer.. what else could it be??
Dominican000 is offline   Reply With Quote
Old 12-07-2009, 09:30 PM   #9
mouab18c1's Avatar
Jump your ecu and find what code its throwing.
http://www.honda-tech.com/showthread.php?t=978933
mouab18c1 is offline   Reply With Quote
eg, d15b7, runs fine below 3000 rpm, won't rev past it, please help bob95egdx Honda Civic / Del Sol (1992 - 2000) 8 01-03-2012 05:55 PM
CRX with ls vtec wont rev past 3000 rpm ole' black crx Honda CRX / EF Civic (1988 - 1991) 11 12-14-2011 02:43 PM
check engine 94whitegsi Acura Integra 3 08-04-2006 08:22 PM
not over 3000 rpms! acc97lxAndy Honda Accord (1990 - 2002) 10 03-28-2004 12:51 PM
88 CRX DX FUEL INJECTION PROBLEM - HELP! EJ2-Fluffy Honda CRX / EF Civic (1988 - 1991) 5 10-04-2003 02:00 AM
Tags
0ver, 2008, 3000, 3k, 95, car, civic, engine, forum, honda, jump, light, rpm, rsx, si, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
