car wont start with new clutch
got the tranny in, tried to start the car it wouldnt start, it wouldnt even turn or crank, when i push the clutch down it doesnt feel like there is any pressure on it, anyonw know whats up, its a stage 2 clutch
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">did you bleed the clutch?</TD></TR></TABLE>
Re: (boostinteg777)
did you open or undo the clutch lines at all?
did you verify the the push rod is pushing the fork mechanism, and hasn't shot out and gotten lost?
did you connect the ground strap to the tranny?
so how can you not disconnect the hydro lines and change the clutch.... It makes it so much harder.. bleed the lines definietly. then if the clutch doesn't engage or dis engage completely your clutch slave cylinder isn't pushing the fork in correctly. now this sucks(its happened to me before) now you have to take the tranny back off disconnect the fluid ines for the slave cylinder. remove starter. Make sure the clip is securing around the head of the rod that the fork sits on. push the fork in and out acting as the slave cylinder would. if it moves properly put the tranny back on and you'll be set. remember to re bleed the lines best thing to do i get a hose that just fits on the nipple and long enough so you can have the bottle of dot3 on the ground, fill up resovour and pump clutch till lines complete close nipple up pump some more should stiffen up dramatically if doesn't then you re bleed. Good luck this is all from experience trust me
Re: (importfan0103)
is it even turning over the starter if not its your ground wire or the starter singal wire its single wire that runs to the starter. also check your grounds in that area there two of them
vtec25
08-04-2006 10:44 PM
peacexisxfree
05-15-2006 05:37 PM
