Car won't start - Clicking starter - loose ground? - Honda-Tech
Old 06-05-2006, 03:00 PM   #1
Default Car won't start - Clicking starter - loose ground?
So I parked my car yesterday, ran into Starbucks for 5 mins to score a drink, came back out and my car wouldn't start.
When I turn the key all the way, the starter clicks, and the relay clicks. When I turn the key to "on" I hear all kind of whines and hums, the dash lights flicker, the "open door" noise disappers, basically everything goes haywire.
-Battery is good (and fully charged)
-Starter is good
-Grounds are good (t-stat housing/chassis/tranny/valve cover)
-Main relay is good
-All fuses are good
What the hell happened? When I push start the car, it runs fine.
EnzoSpeed is offline   Reply With Quote
Old 06-05-2006, 04:00 PM   #2
Default Re: Car won't start - Clicking starter - loose ground? (EnzoSpeed)
Out of ideas
Old 06-05-2006, 04:04 PM   #3
Turbogixxer's Avatar
Battery cables and connectors.
Turbogixxer is offline   Reply With Quote
Old 06-05-2006, 04:21 PM   #4
Default Re: Car won't start - Clicking starter - loose ground? (Turbogixxer)
I know, but I'm stumped. It's a new battery with new terminals and the grounds are all aftermarket 4 gauge with gold terminals.
All I can think of is that it's not the negative side but the positive side. Where does the 12+ power go after it enters the underhood fuse box?
Old 06-05-2006, 04:25 PM   #5
it goes to the fuses. You have a 4 guage wire that goes from teh battery to the starter to power the motor. I would check that wire.
Try to crank the motor (12v to the s-termial on the start) and measure the voltage going to the starter. You hcan always run a battery test, record the data, then place the postive side connector of the tester on the 4 guage wire at the starter and see the data. A big difference in data means the wire is bad. That will cause your problem.
Old 06-05-2006, 04:27 PM   #6
non-VTEC's Avatar
could be the starter just took a ****..........try tapping the starter with a hammer and see if it starts?
OR it could be a bad ignition switch.......i have see a few of those go bad recently.....
non-VTEC is offline   Reply With Quote
Old 06-05-2006, 05:04 PM   #7
Default Re: Car won't start - Clicking starter - loose ground? (non-VTEC)
The problem is definitely not the starter or ignition switch.
Power is not looping somewhere, like there's a short. The lights are dim and the hazards won't even turn on (relay just buzzes). But the battery is fully charged.
Basically, all the symptoms of a dead battery but the battery is a one year old Optima yellow top and it's fully charged.
I just doubled checked the grounds, as well as the power wires going to the starter and fuse box.
Old 06-05-2006, 05:06 PM   #8
Quote:
How did you test everything? IF you charge the battery or think it is charged?
Old 06-05-2006, 05:20 PM   #9
I checked all the wires with a multitmeter. I had the starter tested at AutoZone. I tried charging the battery, but my charger goes straight to trickle because it's already fully charged.
Old 06-05-2006, 05:26 PM   #10
Go to autozone and have them check it this way.
It sounds like a connection problem.
Old 06-05-2006, 08:00 PM   #11
There goes 5 hours of my life. It was my new Optima battery . There goes $180
Old 06-07-2006, 01:08 PM   #12
I smell a ninja edit
I've contacted Optima. Trying to get a refund. Apparently the model 51 yellow tops are notoriously defective.
Old 06-07-2006, 01:44 PM   #13
Si Shane's Avatar
I got pwned by this:
and then had nothing to contribute.
Si Shane is offline   Reply With Quote
electrical help needed! starting problem integra uniquerider Tech / Misc 11 08-13-2015 12:00 AM
Clicking starter relay. no start. 0 volts at starter terminal Schultzie Tech / Misc 4 01-23-2013 10:46 PM
1993 Civic EX intermittent start problem freek21 Honda Civic / Del Sol (1992 - 2000) 2 06-27-2012 06:13 PM
1988CRX Starting Problem bywaters Honda CRX / EF Civic (1988 - 1991) 16 01-14-2009 06:04 PM
buzzing/clicking main relay HamiltonRex Honda CRX / EF Civic (1988 - 1991) 4 06-29-2004 03:03 PM
Tags
91, battery, clicking, clicks, dead, ground, honda, hondatech, integra, loose, odyssey, start, starter, symptoms, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
