car shut off while making a turn - Honda-Tech
Old 07-22-2005, 05:45 PM   #1
hondamama7894's Avatar
Default car shut off while making a turn
As the title says, my car totally turned off while I was making a turn. Earlier before this happened I was stopped, and it acted like it wanted to stall, but didn't. I have a couple ideas what it could be but not too sure. Any help would be greatly appreciated.
hondamama7894 is offline   Reply With Quote
Old 07-22-2005, 06:00 PM   #2
SnIpErS-GsR's Avatar
Default Re: car shut off while making a turn (hondamama7894)
Possible vacume leak? I know that vacume leaks make the car almost stall out. Maybe a short in the electrical system somewhere? Anyone work on your car lately?
SnIpErS-GsR is offline   Reply With Quote
Old 07-23-2005, 09:03 AM   #3
Reason's Avatar
Was your car low on gas? This use to always happen to me when I was low on gas, but i also had a walbro fuel pump and this is a common thing.
Reason is offline   Reply With Quote
Old 07-23-2005, 09:45 AM   #4
jdm420da6's Avatar
Default Re: car shut off while making a turn (Reason)
does it totally turn of electrically, or does the motor just stall....
if its stalling, do u have a powersteering, if so, do u have a p/s oil leak? or maybe it could be a bad p/s oil pressure switch. when u make a turn the motor likes to die or come close to it cause of the extra stress when u turn, the p/s pressure switch fixes that by telling the ecu to bump the idle a little when u turn. if that switch is bad, it could be causing ur motor to stall.
jdm420da6 is offline   Reply With Quote
Old 07-23-2005, 12:33 PM   #5
The motor acted like it wanted to stall earlier in the day at a dead stop, but didn't. It totally shut off all power to the car. So i guess its not really stalling, just shutting off completely.
Old 07-23-2005, 03:05 PM   #6
jdm420da6's Avatar
so no lights stay on in your dash after it dies...?like the check engine light etc..etc...check ur ignition system..or ur ign. switch.
radio issue Will Sosa Introduce Yourself 0 09-29-2015 08:37 PM
Help? dallaslove Honda Accord & Crosstour (2003 - Current) 1 09-24-2015 04:56 PM
2008 Accord GPS and Radio Cycling On and Off HondaInquiry Introduce Yourself 0 02-19-2014 06:45 AM
Oil Light comes on Sohc Driver Acura Integra 9 07-09-2003 12:38 PM
System !POPS! when car shuts off...HELP watacivic Audio / Security / Video 13 12-23-2002 01:08 AM
Tags
255, car, civic, dies, honda, making, reason, shut, stalled, stalling, stalls, tech, turn, turns, uturn, vehicle, walbro
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
