car shakes when accelerating/making right turns...
Old 04-19-2006, 06:53 AM
See Are X's Avatar
Default car shakes when accelerating/making right turns...
when accelerating, my car starts to shake like i'm hitting small potholes in the road. The steering wheel doesnt really shake, I feel it more at the bottom of my feet. It feels worse when im making right turns, and doesnt really do it when making left turns.
UPDATE 4/28:
-changed my passenger side axle
-replaced passenger side inner tie rod
-rebalanced tires
-got an alignment
...and still nothing...I just bought a driver side axle and i'm gonna see if this helps...
Modified by See Are X at 6:00 PM 4/28/2006
Old 04-19-2006, 07:26 AM
Miracle's Avatar
Default Re: car shakes when accelerating/making right turns... (See Are X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">-the passenger side wheel has about 3-4mm of play, holding the wheel at the 3 and 9o'clock position and moving it left and right. I'm thinking the inner tie rod might need to be replaced?
-the driver side wheel has about 2-3mm of play, holding the wheel at the 6 and 12o'clock position and moving it up and down.</TD></TR></TABLE>
Tie rod end on the right and ball joint on the left. The up and down motion you were talking about checks the play in the lower ball joints, and you can move it in the slightest bit, that will produce a vibration due to the joint not being 'tight'
Old 04-19-2006, 08:05 AM
civicstar's Avatar
Default Re: car shakes when accelerating/making right turns... (Red7thGen_ex)
also check the axle, if it is alittle broken, it will do that and also check if the axel nut is in tight
Old 04-19-2006, 09:35 AM
See Are X's Avatar
Default Re: car shakes when accelerating/making right turns... (civicstar)
could blown shocks have anything to do with it?
Old 04-19-2006, 10:46 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">could blown shocks have anything to do with it?</TD></TR></TABLE>
a blown shock wont do anything but mat that corner sag, and pull torwards that direction. If youve got a blown shock, its obvious. But when you can move the tire on the hub back and forth like that, its a ball joint. And since most honda ive worked on only have a lower balljoint, that would be my first guess. Maybe im wrong, but the hondas ive seen, mine included only have 1 balljoint per side.
Old 04-19-2006, 01:24 PM
Shreik's Avatar
6 and 12 sounds like balljoint.
3 and 9 is tie rod, it could be the inner or outer. Most likely inner.
Take off the tire and move it on the 3 and 9. You will see the rod go in and out of the boot or the hub will move at the outer tie rod mount.
That will answer your question as to which it is.
I have a pass side outer tie rod NIB for a 5th gen civic. If u need it and it fits your application. let me know.
Old 04-19-2006, 03:30 PM
sc4dr's Avatar
wheel bearings have slop in them? Are you running stock diff, maybe it's taking a dump.
Old 04-19-2006, 03:45 PM
See Are X's Avatar
Default Re: car shakes when accelerating/making right turns... (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearings have slop in them? Are you running stock diff, maybe it's taking a dump.</TD></TR></TABLE>
wheel bearings didnt look like they had any slop in them...and im running a itr tranny(stock diff)...I really hope its not my tranny. I was worried it might have been my tranny, so I made this post a couple days ago...
https://honda-tech.com/zerothread?id=1594932
Old 04-19-2006, 05:32 PM
homiegdogfool's Avatar
if you drove it not knowing that the boot was ripped it could have fucked with alot of other driveing componets
Old 04-19-2006, 07:28 PM
red91sit's Avatar
Default Re: car shakes when accelerating/making right turns... (homiegdogfool)
Reaally? because a torn boot just sprays grease everhwere and allows contaminents into the axle. What could it possibley harm?
Also, unlikely, but are the tires still round? Mine would do this all the time, and it turned out to be a bulging tire. Which exploded violently on the highway. Yours doens't sound like that since i'ts just under acclereation turning, but something to look out for.
Modified by red91sit at 10:40 PM 4/19/2006
Old 04-21-2006, 07:33 AM
See Are X's Avatar
Default Re: car shakes when accelerating/making right turns... (red91sit)
I just really hope its not my transmission. I'm probably going to try and replace the pass. inner tie rod next.
Old 04-28-2006, 02:00 PM
See Are X's Avatar
update up top
Old 04-29-2006, 01:11 AM
EFin' Kyle's Avatar
was teh axle bad at all? once i was short on cash and drove alittle to long on a bad axle and i busted my wheel bearing. not a fun ride. =P check the wheel bearings
-Kyle
Old 04-29-2006, 06:11 PM
techb's Avatar
Check the play in the inner axle joint. Could be that or maybe not?
Old 04-30-2006, 03:00 PM
See Are X's Avatar
I changed the driver side axle and it kinda fixed the problem. It still shakes but really not that violent. Its probably time to replace my ball joints too.
Dunlop FM901's = very grippy tires
Modified by See Are X at 7:16 PM 4/30/2006
dtran002
07-03-2010 10:13 AM
Turbo_Mike
Suspension & Brakes
10-19-2005 09:29 AM
00ekcoupe
11
08-27-2005 10:58 AM
Vince_badaz
05-12-2003 11:03 AM
rltrock
03-04-2002 06:36 PM
Quick Reply: car shakes when accelerating/making right turns...
