Car shakes, rear wheel bearing?? - Honda-Tech
Old 08-10-2004, 01:48 PM   #1
jdmstreethatch's Avatar
Default Car shakes, rear wheel bearing??
Okay I just had a front and rear aligment and my rear tires balanced and my car still shakes and produces a lot of road noise from the rear at about 60kph. Ive also replaced the drivers side rear wheel bearing which makes me think maybe the left side bearing needs to be replaced too. Whenver im making a right hand turn or even pull the steering wheel to the right the sound and vibration goes away BUT if i make a left hand turn or pull the wheel to the left the sound (road noise) and vibration is still there.
Does this sound like a rear wheel bearing?
thanks alot
chris
jdmstreethatch is offline   Reply With Quote
Old 08-10-2004, 02:37 PM   #2
Chiovnidca's Avatar
Default Re: Car shakes, rear wheel bearing?? (jdmstreethatch)
Quote:
Sounds like a wheel bearing, it wouldn't be likely to cause a vibration though. Are any of your tires chopped? That can cause a similar noise and a vibration also.
Chiovnidca is offline   Reply With Quote
Old 08-10-2004, 02:48 PM   #3
you mean like a piece missing out of the tire? i dont think there is but i havent really checked. but, that wouldnt explain why the noise goes away when i turn to the right would it?
Old 08-10-2004, 03:13 PM   #4
Chiovnidca's Avatar
Default Re: (jdmstreethatch)
Usually wheel bearings do that. A "chopped' tire has the tread worn in patches, if you rub your hand aver the tire you will know.
Old 08-10-2004, 03:19 PM   #5
Default Re: (Chiovnidca)
the tires are brand new so i doubt its the tires.
so do you think i should change the rear wheel bearing?
Old 08-10-2004, 03:20 PM   #6
Chiovnidca's Avatar
If that's the bad one.
Old 08-10-2004, 04:36 PM   #7
up....any more opinions??
Old 08-10-2004, 04:36 PM   #8
redlineintegra's Avatar
Alot of times the vibration comes from a bad inner cv joint, typically if the axle is old, or a remanufactured unit. I have experienced this more than I like to admit on my Integra
redlineintegra is offline   Reply With Quote
Old 08-10-2004, 05:22 PM   #9
Default Re: (redlineintegra)
yeah but if the problem was in my axel wouldnt i feel it through the steering wheel?? the vibration i feel is definatly from the back not thru the steering wheel.
Old 08-10-2004, 06:06 PM   #10
nsxmatt's Avatar
Jack the car up and see if there is any play in it. You can also remove the wheel and drum and turn the hub by hand and feel if it's bad.
nsxmatt is offline   Reply With Quote
Old 08-10-2004, 06:41 PM   #11
yeah i tried pulling on the wheel but there is no play. i heard it has to get pretty bad before that happens.
if i turn the hub will it drag if its bad or what should i be looking for?
Old 08-10-2004, 10:23 PM   #12
up for more opinons....the rear bearing/hub aint cheap so i want to make sure thats the problem
Old 08-11-2004, 04:10 AM   #13
Chiovnidca's Avatar
Spin it. Is it noisy?
Old 08-11-2004, 06:36 AM   #14
JimBlake's Avatar
It's not about OPINIONS over the net. You've got to check it out yourself.
Quote:
There's no substitute for actually doing that. A bearing can go bad by getting tight & rough. When that happens, it makes noise, but it doesn't get loose. You have to get the brakes completely out of the picture in order to feel whether the bearing is smooth.
JimBlake is offline   Reply With Quote
Roaring noise shane2121 Honda Accord (1990 - 2002) 4 01-19-2013 01:31 PM
Wheel bearing sound! avio Honda Accord & Crosstour (2003 - Current) 4 04-11-2010 01:40 PM
Odd noise Deano_d Honda S2000 8 12-12-2009 08:16 PM
Recent noise makes nightmare of an issue oldskooldaboy Suspension & Brakes 0 12-20-2006 03:03 PM
sway bar and left wheel shakes ixcryxblood Honda Prelude 1 02-28-2005 03:30 AM
Tags
back, bad, bearing, bearings, car, honda, lot, making, noise, rear, road, s2000, shake, shakes, tire, turning, vibration, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
