cap and rotor
cap and rotor
is there anything i should know before replacing my cap and rotor...second whats the best way to get the screw to remove the rotor lined up in the position to remove it....(96 integra se)
Re: cap and rotor (teg-your-it)
1. Make sure you get the right cap+rotor. I recommend getting oem parts. Alot of aftermarket parts are not that great.
2. To line up the rotor, you can get a deep 19 mm socket and rachet and turn the crank pulley.
Re: cap and rotor (1bad-eg)
i ordered the bosch cap and rotor with ngk plugs and wires...bosch fuel filter and k&n air filter drop in....sound good for a decent tune up?
