cant tight my lower balljoint
1 Post
brand new balljoint installed in by one of the tech where I work
everytime I try to tight the balljoint the the bolt will turn with the nut , is there any technique to do this ?
Re: cant tight my lower balljoint (super-hatch)
whatu do is put a skinny vice crip on one end,u put it in the whole and u put the bolt on even. u hold the vice grip down and u take an impact gun and shoot it in enough and take the vice grip off and shoot the rest in, works every time for me
1 Post
Re: (base-op.1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by base-op.1320 »</TD></TR><TR><TD CLASS="quote">I just put a jack under the control arm to put pressure against the ball joint - holds it perfectly fine</TD></TR></TABLE>
got it done what I did was put the wheel on and let it sit in the ground and tight it up with a wrench worked fine
93(Civic)EG6
09-01-2007 08:06 PM
itsjdmbradyo!
10-04-2006 01:31 PM
