Cant Split the case on my D-series - Honda-Tech
Old 04-28-2008, 07:16 AM   #1
lulz
92BluEH-3's Avatar
Default Cant Split the case on my D-series
Alright im trying to get the case to split on my d-series tranny and i can slide he housing and box apart only about an inch but then it just gets hung up on something. Ive read about a counter shaft c-clip but only found info for it on b transmissions. Is there one on the d-series and how the hell do i get it off?
92BluEH-3 is offline   Reply With Quote
Old 04-28-2008, 03:04 PM   #2
hatchling37's Avatar
Default Re: Cant Split the case on my D-series (92BluEH-3)
There is one on the D also. You have to take out the large sealing plug at the top (opposite end of the exposed mainshaft) of the case. Put your 3/8" ratchet in there and remove it. Then you have to get a pair of snap ring pliers or a couple of flat blades and spread that beotch apart. Then once it's expanded, tap the case and it should come off with minimal monkeying.
hatchling37 is offline   Reply With Quote
Old 04-28-2008, 07:00 PM   #3
lulz
92BluEH-3's Avatar
Default Re: Cant Split the case on my D-series (hatchling37)
Yea i figured that out i just seen that plug and i thought hell its worth a shot. and whaddya know there it was.
oh and thanks for being intelligent and not a d-bag, like most of h-t
Old 04-29-2008, 08:56 AM   #4
1992Si's Avatar
Also check the sticky at the top of this forum.
1992Si is offline   Reply With Quote
Old 04-29-2008, 09:01 AM   #5
lulz
92BluEH-3's Avatar
Default Re: (1992Si)
ahhhh my bad i musta missed it
Tags
case, civic, crx, dseries, honda, httpsplitting, series, split, splitting, tranny, transmison, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
