check engine light on, code 41, what does it mean?
Old 01-28-2003, 10:35 AM
kayoken's Avatar
Default check engine light on, code 41, what does it mean?
check engine light is on, i checked to see what code/s it has, and it gave me one code, "41" --- are there any websites that has a list of the codes? thanks for the info... the motor by the way is a 95gsr with 95gsrECU in a 2k civic ex.
Old 01-28-2003, 11:45 AM
Kataku2K3's Avatar
Default Re: check engine light on, code 41, what does it mean? (kayoken)
A CEL 41 indicates that there is something wrong with your primary oxygen sensors heater (i guess you only have one O2 if you're running an OBD1 ECU anyways).... It could be in the wiring but if you've been running your GSR for awhile with no CEL i'm willing to bet that your O2 just went out... Replace it with a new one and you should be fine... Peace
Lithel
10-03-2007 07:14 PM
OneBadVTEC
06-16-2006 05:34 AM
Patron
03-23-2004 04:17 AM
PM-Performance
11-30-2001 10:53 AM
Yellow Dragon
08-05-2001 01:04 PM
Quick Reply: check engine light on, code 41, what does it mean?
