can someone tell my why my car runs better with the TPS unplugged?
Old 05-06-2008, 04:46 AM
  #26
gimmezell's Avatar
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">When you open your ROM in Crome and look in view/options there are 3 O2 options.
1. Disable Oxygen Sensor (Open Loop)
2. Disable Oxygen Sensor Heater
3. Debug Mode (Disable O2 and more)
So I would assume that if you are to check the disable O2 (open loop) check box. That would disable closed loop IIRC.</TD></TR></TABLE>
I checked all three and it still does it, but not as bad.
I guess I'm back to unplugging the TPS.
Old 05-06-2008, 03:45 PM
  #27
Brick Top's Avatar
Default Re: (all-in)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-in &raquo;</TD></TR><TR><TD CLASS="quote">got a friend who has same problem. car bucks when coasting in gear when foot is off the gas, but runs fine on the highway.</TD></TR></TABLE>
that right there was the first symptom of my tps going bad. got worse from there on out.
OP, did you ever switch out the blox tps for an oem?
Modified by Brick Top at 7:54 PM 5/6/2008
Old 05-07-2008, 07:11 AM
  #28
gimmezell's Avatar
Default Re: (Brick Top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brick Top &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Brick Top at 7:54 PM 5/6/2008</TD></TR></TABLE>
No I haven't found an oem yet. I'm still looking though. Do I need to use a OBD2 tps?
Old 05-07-2008, 07:42 AM
  #29
GhostAccord's Avatar
Default Re: (gimmezell)
OBD doesn't matter and I'm also pretty sure that you can use a tps from any Honda car. It doesn't have to be the same make/model/year IIRC. I was using an OBD1 TPS from a Civic on my OBD2 96 Accord.
Modified by GhostAccord at 9:22 PM 5/7/2008
Old 05-07-2008, 12:44 PM
  #30
I'm Huge In Japan
VegasInvasion's Avatar
Default Re: can someone tell my why my car runs better with the TPS unplugged? (gimmezell)
Pull apart & clean your FIT (fast idle thermo valve) with some carb cleaner, and replace your MAP (manifold absolute pressure) sensor. Also, clean out the little hole for the MAP with some wire and carb cleaner, make sure it's not clogged. These fixed my B18C with the same problem.
PS for a Blox TPS, make sure it idles with a 0.5v signal (you might need to loosen it and twist it around). Leave it connected or you'll clog up your cat & O2 sensor again, all it's doing is running super rich. Also, make sure you have the notch under the TPS in between the grooves, or it obviously won't detect your throttle position. You probably already know that, but just FYI.
Old 05-07-2008, 03:29 PM
  #31
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gimmezell &raquo;</TD></TR><TR><TD CLASS="quote">
No I haven't found an oem yet. I'm still looking though. </TD></TR></TABLE>
try one and get back to us.
Old 06-07-2009, 08:51 PM
  #32
egbangin's Avatar
yeah man the same things happenin to my ek.. tps doesnt work? .. ima try cleanin my FITV n map. out. maybe thatll. help.. ill get bak to u guys.. and let u know on my progress.
SovXietday
64
06-11-2019 06:42 PM
petr0lb0mb
Engine Management and Tuning
04-06-2017 05:13 PM
dosstraflamus
11-24-2014 07:31 AM
1badteg
09-12-2009 03:38 PM
jdm_vtec
06-03-2007 06:38 PM
Quick Reply: can someone tell my why my car runs better with the TPS unplugged?
