buddy club cam gears degree markings
Old 04-14-2012, 12:46 AM
raverx3m's Avatar
Default buddy club cam gears degree markings
i keep searching the internets but cannot find a slid answer
how many degrees each mark on these cam gears?
Old 04-14-2012, 04:45 PM
raverx3m's Avatar
Default Re: buddy club cam gears degree markings
or at least how many degrees is one tooth.
Old 05-01-2012, 11:22 PM
raverx3m's Avatar
bump
so after some photoshopping it seems they are 2 degrees each mark.
so my timing was off 2 degrees on the cams meaning it was 4 degrees off on the crank?
can i calculate how much my head was milled if i know those numbers?
so does this mean that my head + headgasket is 1.75 mm shorter?
damn that means im gonna be around 13.2 compression lol. lucky i didnt go with ctr pistons
Old 05-02-2012, 07:17 PM
stumpyf4's Avatar
Cams move at half the speed of the crank, 2 deg at the cam is 1 deg at the crank.
Old 05-02-2012, 08:45 PM
raverx3m's Avatar
oh i thought it was opposite.
but still doesnt change that 2 degrees on cam gears = .04 shorter distance
.04 for every 2 degrees is that right? i cant find it anymore
Old 05-03-2012, 03:56 AM
non-VTEC's Avatar
1 cam degree is equal to 2 crank degree
**edit** the marks on those BC gears look larger/wider apart compared to others....they could be 2 degree each???
Old 05-03-2012, 05:00 PM
raverx3m's Avatar
Yep they are 2 degrees each
Old 05-04-2012, 03:23 PM
stumpyf4's Avatar
Brain fart!!!
Old 05-04-2012, 05:33 PM
raverx3m's Avatar
if you divide the cam into 90 degree sections each section has 9 full teeth which makes each tooth 10 degrees. and there are 5 marks per tooth
AfTeRhOuRs209
15
05-01-2011 08:58 PM
donnjuan2point2
03-04-2004 04:40 PM
nigel
02-09-2004 11:20 AM
Quick Reply: buddy club cam gears degree markings
