fuel pump, injectors, or dizzy?
Ok so i just got mt car running againg 92 civic sohc zc bottom y8 head on stock p28....
At first my fuel pump wasnt prime when i turned the key, got a new main relay problem fixed and now when i drive it sputter and pops when at normal engine operating temp from like 2 1/2 - 4k rpm ..... but if i floor it ,its like goes back to normal. Idles good when cold but low and a little rough when cold ..... what do you guys think it could be
Re: fuel pump, injectors, or dizzy?
Carbon deposits in the EGR valve can cause it to stick open a bit and cause a rough idle. If it is bad enough, the engine will stall out when you slow to a stop
1st check ur timing..make sure its top dead center when u do it. after that check your dizzy, if that fails then it may be the injectors or faulty map sensor
Yeah i was about to say no egr valve.... all timming marks match up on point .alo checked ignition timming with timming light ... no check engine i didnt switch the tps and map i remember the wire colors for the map ...... ground are clean as well
88 rex
17
08-18-2005 10:05 AM
