Both radiator hoses are hot.. is that normal?
Old 09-15-2008, 04:36 PM
hybrid90's Avatar
Default Both radiator hoses are hot.. is that normal?
So I just replaced a new radiator, OEM thermostat and upper/lower radiator hoses. Topped off coolant and bleed **** like that and let the car idle till the fan came on.... now my question is... are both the upper/lower hoses supposed to be hot or upper hot lower warm?
Both of my hoses feels like the same temp.. HOT! Is this normal? I remebered before I replaced the radiator, after driving, the upper would be hot and the lower would be warm.. but now both are really hot..
Temp gauge is normal to below middle...
Car is a 97 Accord..
Old 09-15-2008, 09:41 PM
projectTeG's Avatar
yes, that means that you car is circulating the coolant. if you lower hose was cool than your t-stat wasn't opening
Old 09-15-2008, 10:51 PM
hybrid90's Avatar
Default Re: (projectTeG)
Hey thanks for the reply! For a minute there, thought I fcuked shiet up
Old 12-13-2023, 06:17 PM
Padronan's Avatar
Default Re: Both radiator hoses are hot.. is that normal?
I understand that the purpose of radiator and fans is to cool the coolant that reenters into radiator, so to me the lower hose should have a somewhat lower temperature than the top one. I would say he either has a semiclosed thermostat that does not open completely or he is using a degraded coolant.
Old 12-14-2023, 06:49 AM
Ryanthegreat1's Avatar
Dude, check the dates on stuff before bumping a 15 year old thread.
In theory yes the lower hose should be cooler. Can you feel that with your hands when everything is up to temp? No. You need tools for that. The delta might only be 10-15 degrees when fully hot.
soon2bdropped
08-15-2010 06:18 PM
IntegraR0064
01-27-2009 10:41 AM
aj_scribble
03-20-2008 10:28 AM
19992civichatch
03-01-2007 10:49 AM
Squirtle
06-06-2006 02:57 PM
Quick Reply: Both radiator hoses are hot.. is that normal?
