Best way to degrease a motor - Honda-Tech
Old 10-23-2002, 01:38 PM   #1
White S2k's Avatar
Default Best way to degrease a motor
My valve seal leaks oil onto the outside of the block
what is the best way to remove this?
White S2k is offline   Reply With Quote
Old 10-23-2002, 01:41 PM   #2
Neddy1081's Avatar
Default Re: Best way to degrease a motor (whiterice42019)
go to the auto store and get this stuff called engine bright(engine degreaser), it will clen ur block up nice and everything else under ur hood
Neddy1081 is offline   Reply With Quote
Old 10-23-2002, 01:41 PM   #3
White S2k's Avatar
Default Re: Best way to degrease a motor (Neddy1081)
hey thanks
Old 10-23-2002, 02:01 PM   #4
frogsr's Avatar
you should fix the problem first... degreasing will only get the gunk off temporarily--it's gonna come back.
frogsr is offline   Reply With Quote
Old 10-23-2002, 02:02 PM   #5
White S2k's Avatar
Default Re: Best way to degrease a motor (frogsr)
yea they putting in new seals when i install my cams and valve train
i have a new head gasket set for it
Old 10-23-2002, 02:04 PM   #6
i think simple green works. and if u use compresswater?
weakGOODJunKieS.com is offline   Reply With Quote
Old 10-23-2002, 02:13 PM   #7
White S2k's Avatar
Default Re: Best way to degrease a motor (importoverdomestic)
what is simple green?
Old 10-23-2002, 02:35 PM   #8
performula's Avatar
It's looks like a Palmolive (same deep green too) container with a Windex head on it.
performula is offline   Reply With Quote
Old 10-23-2002, 02:59 PM   #9
Steve91's Avatar
Don't use Engine Brite or any other engine degreaser on your car. It will discolor aluminum components and is very hard on the paint and rubber in your engine bay. Go to the grocery store and buy Simple Green. You can also get it at the autoparts store. It works wonders. Just spray like crazy, let it sit for 10 minutes and then hose down.
Steve91 is offline   Reply With Quote
what is the best way to install a ctr lip ? JDMEK- Honda Civic / Del Sol (1992 - 2000) 11 01-13-2010 05:09 PM
Best way to transfer money, bank to bank. __oversea General Discussion and Debate 11 11-02-2009 10:48 PM
best way to remove window tint streetracerof06 Honda / Acura 6 11-30-2005 08:53 AM
tar removal sound deadening material stripping all stock Honda Civic / Del Sol (1992 - 2000) 21 04-28-2003 04:55 PM
Best way to remove pin strips GReddy SI Honda Civic / Del Sol (1992 - 2000) 13 12-11-2002 12:04 AM
Tags
auto, brite, county, degrease, degreaser, degreasing, discoloring, engine, engines, honda, motor, motors, oil, orange, southernca, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
