Trying to located the right main and rod bearings i need
Old 10-23-2002, 07:43 AM
NeXtLeVeL_TyPe_R's Avatar
Default Trying to located the right main and rod bearings i need
I got one of the main caps off already and the bottom halve of the bearing is a brownish color -can i assume that the rest of the main and rod bearings are also brown.
I am trying to make sure i order the right ones as replacements
Thanks ahead of time
Old 10-23-2002, 08:44 AM
IN VTEC's Avatar
Default Re: Trying to located the right main and rod bearings i need (NeXtLeVeL_TyPe_R)
you shouldn't assume the same. don't take bearing clearances lightly.
you need to plastigage a new set.
get a set acl's and plastigage them. even if you can't use them you can still sell them to somebody else who can.
Old 10-23-2002, 10:41 AM
civicguy's Avatar
Default Re: Trying to located the right main and rod bearings i need (IN VTEC)
i got a new set of acl main bearings,thrust washers for $50 if you want them email me
Old 10-23-2002, 10:46 AM
Mover's Avatar
Message Earl or Rocket. They sell ACL. Can't go wrong
Old 10-23-2002, 11:26 AM
CHEETAH's Avatar
the color is located ont eh side of the bearing, the browning color at the bottom is heat marks not the bearing sizing color.
greg
Old 10-23-2002, 12:32 PM
Default Re: Trying to located the right main and rod bearings i need (CHEETAH)
greg
actaully it is the side of the bearing that has the brownish color --- does this mean i can go ahead and order and brown set.
stock 90 integra ls motor
Old 10-23-2002, 12:34 PM
BROOD's Avatar
Are they all brown or did you only look at one bearing. Actually it is possibly that every bearing could be a different color. Plus you need to be careful by just looking at the color bands.......oil and time have there way of discoloring those color bands. I'd select my bearings by reading the jounal and bore letters/numbers and then plastigauging them to make sure.
**edit** plus your rod bearings are going to be different all their own also.
A set of standard size ACL bearings (rod and main) will most likely work for you. Just make sure to plastigauge them also.
Rocket or Earl can both set you up with ACL bearings for a good price.
[Modified by SLPR, 1:36 PM 10/23/2002]
[Modified by SLPR, 3:11 PM 10/23/2002]
Old 10-23-2002, 01:49 PM
New User
blkDOHCsol's Avatar
Default Re: Trying to located the right main and rod bearings i need (SLPR)
may I also recommend the acls.. for rocket
truKalypso
05-18-2010 09:24 AM
rice a roni
04-06-2008 11:37 AM
amadriga
02-12-2008 04:27 AM
black99x
07-09-2006 06:25 PM
SPEED123
04-13-2003 06:09 PM
Quick Reply: Trying to located the right main and rod bearings i need
