Best car battery... - Honda-Tech
Best car battery...
Old 05-27-2011, 10:52 AM   #1
FlewByU352's Avatar
Default Best car battery...
Long story short I need a new battery ASAP as mine just tested half the rated cranking amps due to the battery being 7 years old now :p. I was wondering what others thought of certain batteries and their experience. So let's here it, what battery do you have and what do you think is the best?
FlewByU352 is offline   Reply With Quote
Old 05-27-2011, 10:57 AM   #2
Builda'Teg_92's Avatar
Default Re: Best car battery...
Well i get OPTIMA yellow tops at a pretty good price so those are the batteries i use, there really great just dont let it die cause it takes a long time to recharge the gel batteries
Builda'Teg_92 is offline   Reply With Quote
Old 05-27-2011, 11:24 AM   #3
FlewByU352's Avatar
Is it worth it for someone to spend $200 on a battery though? The CCA is the same as every other battery that is half the price.
Old 05-27-2011, 11:34 AM   #4
i just use oem batteries. the one in my 97 integra was original until it died a year ago.
kyden is offline   Reply With Quote
Old 05-27-2011, 02:30 PM   #5
Quote:
dont be so narrow minded its not just about CCA..
A)The spiralcell design imobilizes the plates from ever touching eachother and shorting out (thats why they look like that)
B)Higher purity lead ($$) that prevents internal corrosion (less self-discharge)
C)polypropylene plastic around the battery (you can leave it on concrete and it wont drain)
D)VERY resistant to vibration (can take a beating)
E)Also sealed better so it emmits less gas (better if you relocate to the back of a hatch, like mine)
Its just overall higher grade.
Sooooo yes i do think its worth it..from experiance.
Old 05-27-2011, 05:29 PM   #6
The Grumpiest
grumblemarc's Avatar
I have a yellow top and am halfway regretting it. If you park your car for any length of the time the battery will totally drain on you. My hatch has a OEM replacement battery we got from Autozone (can't remember the brand) and has been sitting for 4 weeks now, Got in it yesterday and it fired right up.
grumblemarc is offline   Reply With Quote
Old 05-27-2011, 08:42 PM   #7
slowcivic2k's Avatar
It will look kinda gay, but get a Ford Motorcraft battery. Best batteries I've ever seen.
slowcivic2k is offline   Reply With Quote
Old 05-27-2011, 10:36 PM   #8
$hawNPeeZyy's Avatar
Since we're on the topic of car batteries anyone try these kind of batteries,
http://www.onlinecarstereo.com/CarAu...n_SK-BT20.aspx
I was also in the market for a decent battery and stumbled across that
$hawNPeeZyy is offline   Reply With Quote
Old 05-27-2011, 11:45 PM   #9
FlewByU352's Avatar
Looks don't matter, I have a marine battery box in the trunk lol. I can fit pretty much any size car battery in there.
Old 05-28-2011, 09:49 AM   #10
me and my friends have never had good luck with yellow tops. they have all died on us within a year.
Old 05-28-2011, 02:36 PM   #11
uberEFtuner's Avatar
Yellow stinger deep cycle, I forget the group or size number. Its for honda. I killed it 4 times and it came right back. Its 4 years old now and still great
uberEFtuner is offline   Reply With Quote
Old 05-28-2011, 04:31 PM   #12
FlewByU352's Avatar
Many good car audio batteries are insanely heavy though. That yellow stinger is 57lbs!!!
Old 05-28-2011, 05:08 PM   #13
rtimeteg's Avatar
Exide or Oem!
rtimeteg is offline   Reply With Quote
Old 05-29-2011, 07:45 PM   #14
mikekh10a's Avatar
i have had no bad experience with yellowtops ever. in my old GSR i had the sound system and all and my yellowtop could handle it no problem. and with my eg coupe, i accidentally left the headlights on, so i turned them off, waited an hour or 2 and started right back up!
mikekh10a is offline   Reply With Quote
Old 05-30-2011, 10:42 AM   #15
Stinger spv35 had it in my civic, now in my accord it weighs 27 pounds
Old 05-30-2011, 07:01 PM   #16
fcm
Old Fart
fcm's Avatar
If you need a batt. to replace the stock one, go with Interstate, I have had mine for 7 years now, stay away from any "Gel" cell type batt., we replace those, when defective and still within lifespan of batt., more often then all other batt. combined. 94
fcm is offline   Reply With Quote
Old 05-31-2011, 04:17 PM   #17
FlewByU352's Avatar
Gell cell batteries do look good on paper though meaning they cannot spill and they take abuse. Optima are overpriced and I hear the quality has really gone down and that batteries don't last. If I get an Odyssey battery IDK how you would return it if it goes dead under the 3 year warranty. My AutoCraft silver lasted 7 years but do I really want to replace it with the same type of battery?
Old 05-31-2011, 04:58 PM   #18
johnjw's Avatar
I'm a fan of any non-serviceable battery, i.e. sealed. The older designs with the removable tops to refill cells tend to leak. If you ask me its not worth the corrosion of the battery tray and cables to go with one of these batteries. Leaking batteries can cause alot of damage if they go unchecked. Who cares what brand. Most are made by one of only 3-4 companies anyways. Besides whens the last time you popped the caps off to add mixture to a low cell.
johnjw is offline   Reply With Quote
Old 05-31-2011, 05:08 PM   #19
FlewByU352's Avatar
I just want to spend the cash once rather than go I should have boughten that. I know some excellent batteries all the car audio people run around here. They are purple, IDK the name. However they weigh over 50lbs! Maybe I am too weight conscious over something that weighs 20lbs more than what I have. I guess the car being so weight sensitive I try to save weight where possible. I figure I added enough weight with big brakes, braces, swaybars... airbags are the next thing to come out.
Old 05-31-2011, 05:14 PM   #20
area522010's Avatar
Been rocking a gold advance auto battery going on 2yrs now. I brought a yellow top last year for my dd and no lie a big waste of money I use to take the car to meets and use to leave my signals on n it use to die quicky in my other car my gold aa with my signals no radio on no probs.
And before someone say it was a bad optima I replaced it twice under warranty. Best bet oem its a proven battery, all these new bs batteries is a waste. If it aint broken leave it a $80 battery is just as good as a $200
area522010 is offline   Reply With Quote
Old 05-31-2011, 05:22 PM   #21
FlewByU352's Avatar
Quote:
Even in a racing environment?
Old 05-31-2011, 06:06 PM   #22
honda are the best for ur honda
cr125r is offline   Reply With Quote
Old 05-31-2011, 06:20 PM   #23
The Grumpiest
Self fulfilling prophecy. I think my yellow top is starting to fail.
Old 05-31-2011, 07:38 PM   #24
johnjw's Avatar
Honda oem are made by Interstate. Which are serviceable, which leak, and suck.
Old 05-31-2011, 10:14 PM   #25
FlewByU352's Avatar
It is without a doubt getting worse and worse by the week. Slow crank isn't the word, the car barely, just barely turned over to start tonight. I always had a passenger and made sure I backed in on the highest spot in case a push start was necessary. I can't even jam out to my music otherwise the head unit shuts off and restarts. I hear this happens when the battery is less than 12 volts to protect the amp. So the drive home I gave her some pulls figuring higher revs would charge the alternator more? lol and I left my music off.
What do you guys run for batteries? slammedasfuck Drag Racing 13 10-13-2005 12:56 AM
where to relocate battery in EK hatch??? jay.dee.em1 Honda Civic / Del Sol (1992 - 2000) 17 12-03-2004 01:30 PM
baker high performance battery question pearlteg Acura Integra 6 07-30-2004 02:50 PM
Battery Tie down problem with lightweight battery? RTW DC2R Acura Integra Type-R 22 05-14-2003 01:26 PM
What batteries do you guys recommend? H23ludedude Honda Prelude 26 04-27-2003 10:41 AM
Tags
2011, accord, audio, auto, autocraft, batteries, battery, car, element, florida, gold, great, honda, hondatech, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
